pauldixonuk
pmc & bryston
Isaac - just ask if you need anything clarifying, lol.
Fig.12 shows the results obtained under identical test conditions for the second sample of the DAC64. Again, the grayed-out trace is without the RAM buffer. There are still a number of spurious tones visible, but now the main characteristic is a large rise in the random noise floor on either side of the spike representing the 11.025kHz tone. The measured jitter level was a moderately high 587ps. Switching in the RAM buffer set to its maximum size (black trace) reduced the jitter to an excellent 169ps and eliminated the noise-floor peak. Most of the jitter is due to data-related sidebands (red numeric markers).
Finally, I am trying a different Miller Audio Research program that will allow me to measure word-clock jitter at sample rates other than 44.1kHz. Because it runs on a different National Instruments platform than the Jitter Analyzer, the results are not directly comparable with what I've been obtaining with the Analyzer. For interest's sake, however, fig.13 shows a similar spectral analysis taken with the new piece of kit while the DAC64 was decoding 96kHz Jitter Test data. The red trace was taken without any RAM buffer, the black trace with the maximum buffer. Again, the peculiar rise in the noise floor around the central tone can be seen without the buffer; again, the buffer drastically cleans this up, as well as reducing the level of high-frequency jitter components. However, it doesn't eliminate the lower-frequency components.
Isaac Sibson said:BerylliumDust - I don't own the IP. If Rob wanted to publish every detail of how it worked, he would.
ChrisPa said:How come it seems to get 2 contrasting sets of reviews/comments? Thoughts/opinions please.
