- Sep 7, 2016
I see Serge posted as I typed. Good point on the telephony yes. Only where lines are miles long can they be classic transmission lines with a characteristic impedance at audio frequencies.
I was not associating return loss with damping factor, the two were just conflated and thus the mis - understanding .I think you're using the term 'return loss' incorrectly, as that term is used in RF to mean the amount if reflection from a misterminated transmission line. It doesn't apply to audio, where lines are never terminated in their characteristic impedance. (except perhaps analogue telephony)
If you mean that a loudspeaker driver's back-emf is more or less attenuated by the amplifier's output impedance, that's a different thing, not return loss.
S
This is where we disagree fundamentally, as I have never ever heard amplifier differences that weren't obvious from the measurements.
I also remind you of the blind tests carried out by James Moir and Associates that showed that the Quad 303, 405 and bridged IIs were indistinguishable, a set of tests replicated by Martin Colloms using different amplifiers, including Naim, Quad and Michaelson & Austin amps.
You might also be aware of the Spanish comparison between a Behringer A500 and a Levinson with the same result.
I've never seen any results from any blind tests that showed up amplifier differences when level matched and kept out of clipping.
If you know of any, other than anecdote, I would be interested in knowing about them.
S
Indeed this is where we disagree fundamentally! I consider the differences between well measuring amplifiers to sometimes be as large as those between speakers.... and often of greater importance because the ear tends to be more forgiving of simple colourations etc than to the often "nasty" sounding problems that amplifiers can introduce. I am aware of the Quad and Colloms tests yes but consider them spurious as the differences subjectively between a pair of Quad II's and a 405 are chalk and cheese. I was not aware of the Behringer A500 against Levinson tests but as I've said before I consider the A500 one of the worst sounding amplifiers I've ever heard so can only conclude the tester was half deaf! I would take Kef Codas driven by the Levinson over Quad ESL63's driven by the A500 every time as a very revealing speaker would reveal the true awfulness of the A500.
There seems little point in protracted debate on this matter as we have both made our opinions clear in the past... you think it as crazy to think amplifiers sound different as to think fuses sound different (at least we can agree on the fuses!)... and I think the differences between the A500 and Levinson likely to be of similar magnitude to those between said Coda's and ESL63's and so huge one would have to be deaf to not find it blindingly obvious.
I respect your technical knowledge and enjoy (most!) debate with you but on the more subjective matters (ultimately all that matters is the illusion of well reproduced music and music itself must by very nature be subjective as is all art) I'm aghast at your opinions I'm afraid.
I find it intriguing that someone who believes all hi fi sounds the same (other than speakers? Or do all speakers flat within +/- 3dB over 40Hz to 18KHz sound the same as well?) has such an interest in the subject and made a career out of it!
It strikes me that were you "in charge of hi fi" we would have never progressed beyond say the Leak Delta 70 or NAD 3020 as both measure <0.1% THD and adequately cover 20 Hz - 20KHz. You will no doubt consider all the R+D I've done into phono stages a waste of time as the ubiquitous "single op amp application note special" used in most budget gear can measure very well
The human ear/brain interface and processing are not well understood by science and I wonder if maybe some people who would pass an NHS hearing test are nevertheless unable to hear things like "muddiness", "harshness", stereo imaging and depth perspective etc etc in a similar way that some people are colour blind??.... It's a possibility anyway
There's an irony to all this of course in that those who reckon there is a huge difference between the sound of different wire and even fuses in mains plugs will no doubt regard my opinions on this in much the same way as I regard the opinions of the "all amplifiers sound the same" brigade!The fact that I cannot say why similar measuring amps sound different yet insist they do sound different will be grist to the mill I'm sure
FWIW on this one an amplifier has maybe 100+ components per channel, some parts have gain, which is not linear, non are literally perfect, negative feedback means some part of the signal goes around the loop more than once etc etc... ie it's an almost infinitely more complicated physical mechanism/process than a metre of wire which at audio frequencies can be regarded as perfect within Ohm's Law
I think a touch of humility would not be mis - placed, or is it your purpose to find fault in everyone's view, which runs counter to yours. Your response to a perfectly reasonable observation is frankly offensive. Whilst you crow about your undoubted achievements, you provide no evidence to support your claims. If you want to debate Hifi, then fine. But, if you simply want to have a "Pop" at everyone, then I'm out. Who, or what was it that created that huge chip on your shoulder?
Personally I consider the whole blind/double blind thing pointless in the context of evaluating equipment you own and have no "skin in the game"/commercial interest over the results. The kind of differences I'm talking about are obvious without going to these extremes.
Do you have a range of amplifiers available and a decent (don't have to be SOTA) pair of passive speakers in your collection?
