Thanks for that - if I've understood correctly then changing the voltage x3 (ie. 0.5 to 1.5V) does indeed give a shift of between 9.5 and 10 dB
the other thing I had come across on the dada site was this passage relating to resistor values for 405 gain reduction:
It's stuff like this that makes me hesitant to simply buy a kit of parts on ebay. Does it also vary from one set of boards to another?
There are three time constants at work in the input circuit. R3C1, R6C4 and R4C2. The gain is changed by replacing R6, so C4 nust be changed to keep the time constants of the input filter and the opa feedbackloop equal. In this way the frequency respone will be flat. But if the gain is changed, the time constant of the DC feedbackloop must also be changed, otherwise ther will be a mild LF 'hump' in the frequency response. So C2 has a given value, R4 is changed to keep the timeconstant ok.
Joost Plugge
