- Oct 30, 2004
I use a Moth MkII with fantastic results. I would advise that you practice your technique on an old LP that you no longer play, Max Bygraves etc (apologies to any Max fans.....) I've had my machine for about a month. The first few goes gave mixed results. I've now got my routine sorted and I can take a crackly old LP and transform it, its remarkable!
I use Moths own fluid sparingly and scrub using a Goldring 'exstatic' which is expensive, but does the job superbly when used with fluid. I found the supplied brush to be poor at getting deep into the grooves. I always rinse the vacuum pad before cleaning each side with purified water and remove any excess before vacuuming away. Unless you are applying far too much fluid you should not have any smearing at all, or as pointed out, have you diluted your fluid if supplied as a concentrate? Discs should be pristine when they come off your cleaner. Use just a few dashes per side, don't flood the surface. Its a waste and unessessary.
Good luck!
KXF
Good luck!
KXF
