Yes, Mine are similar to the Kensai in the approach to tuning principles (although the Rhapsody -3dB point occurs 15 Hz or so lower down). I think that a lot of manufacturers deliberately tune for a higher (hump" as this makes small boxes sound more impressive on first listen). I wasn't really suggesting that all attempts to lower the tuning point wouldn't work properly due to Fs, Qts etc, just that optimal (ie flat) tuning volume is dictated specifically by the Vas of the driver and it's Qts figures.
TDrivers will work in boxes generally speaking up to twice the volume or half the volume IF their Q characteristics allow a response which is neither too under-damped nor over-damped at those volume extremes. Generally a 25% tuning ratio applies (so if optimal volume is doubled, then tuning should be 25% lower...providing that it doesn't coincide with the driver's resonant frequency).
The effects of taking a smaller than optimal enclosure and also DROPPING the tuning frequency would be to create a much earlier roll-off point, although less steep a roll off; ie roll-off would start much higher up the frequency range so bass SPL drops and the speaker loses impact at certain frequencies.
Every designer though has their own particular preferences depending on what the end goal to be achieved is.
