firefox question...
julian2002
Muper Soderator
Bedfordshire
hi,
i'm trying to set up a clone of one of the accounts on my pc. i'd like to be able to take all the bookmarks, passwords etc. from ff across from one account to another. there's no obvious way opf doing it - outlook seems ok as i just archive everything off and then import it in the new one but nothig on ff seems to do the same thing.
any ideas or am i soal.
julian
For Bookmarks you need to go to Bookmarks > Manage Bookmarks > File > Export...
That outputs a file which you can import after a reinstall etc.
For a complete cloning you may need to look into the C:\Documents and Settings\XXXXX\Application Data\Mozilla folder (where XXXXX is the XP user name) and copy this from one account to another. This should give you bookmarks, extentions, passwords and everything else you require. You might have to fiddle with the XP side of things so as to get the access sorted so you can sthen see the source folder from the target account.
I usually just copy bookmarks.html and cookies.txt from the profiles directory -- it's easier to re-install extensions and themes manually imho.
