how do i get f4
themadhippy
seen it done it smokin it
by the cross
trying to get my mouse working,found some instructions that work, however it set the mouse right side button to forward and i want it to be close (alt + f4),found the relavent bit of code
None, Up, Alt_L|Left
None, Down, Alt_L|Right
"(null)"
ive replaced "Alt_L|Right" with "Alt_F4" , "Alt_f4" "alt_ " and pressed the f4 key and sevral other combinations, all have failed any ideas? is there a secret code for the f4 button ?
o and the supplyed mouse software dosnt want to talk to linux
nope still no luck :banghead:still defaulting to forward,think i'll try assigning "ctr+del+backspace" to it instead :JPS:
