bob mccluckie said:
Sadly Sid and Coke's method will not work because at the moment of the 'flick' all the accumulated dust will immediately return and spread itself all over the vinyl due to static induced by the brush.
Sniffing is the only way believe me.
Or you could try stealing an amber rod from your local high school that you could rub with a duster and induce the dust off by static attraction that way.
Bob
To a certain extent i would agree Bob. The extent of my agreement would be completely dependent on the degree of static Electricity on the record surface prior to swishing with the carbon fibre brush. I have found that If i use my method on either a brand new record or, one that has not been cleaned using a wet/vac machine then yes, the majority of the dust will be attracted back to the record surface .
If, however, the record has been cleaned properly, i find that it will retain anti-static properties for many, many playings/months afterwards, even if stored in the cheapo, un-branded, poly-lined record sleeves that i use after cleaning.
Once a record is static free then getting the dust off is childs play, one could even blow it off. A record laden with static is always going to be a problem.
To look at it another way, if a record can have a static charge that is so powerfull that it will attract a relatively heavy felt mat off the platter, then a microscopic dust particle doesn't stand a chance of ever escaping the motherships tractor beam.
Get rid of the static , you get rid of the dust.
Does anybody use a Milty Zerostat pistol thing and does it actually work ? I've always wondered about that, and if they do would one of them hand held gas cooker igniter thingies do the same job ??
