Its still driven the same way. The difference is in the complex vibration of the panel of an NXT, where as a speaker cone should not (theoretically) experience any vibration in its own surface, it is meant to vibrate the air next to the surface.
SteveC said:Yes, a non-pistonic way
Anex said:Uncle Ants: Probably a bit of both. It is getting better, like I said, it looks to be big in PA where you can just drop one in in place of a suspended ceiling tile
<snip>
Part of the problem with the ceiling tile types is you have to put it in a box as part of the fire regulations and this acts as a cabinet which the nxts don't like so it doesn't work properly. It'll get there though. At the moment it doesn't look as though it'll ever replace conventional hifi loudspeakers but who knows?
7_V said:The exciters are really just vibrators. You could get a similar effect if you pressed the back of a moving coil driver against a polystyrene or cardboard panel - in other words, just work the panel off the vibrations from the driver.
I've got two different exciters that I'm experimenting with. Both look like small, conventional MC drivers. One type has a plastic ring (instead of a cone) held in a traditional spider. The ring moves just like a cone but with very low excursion. The other type has a plastic ring/spider all-in-one mechanism but the ring is still moved like a conventional cone, albeit with a miniscule amount of movement.Anex said:Thats what I meant, as I understand it, the vibrator is just a piston moving in the same way as any other transducer, is that incorrect?
do you mean line arrays? one of the best ive heard is the nexo geo systemm.very small,very directional,and a very nice soundNXT is going to be huge in PA. No its not NXT, it uses lots of conventional drivers mounted in set positions
7_V said:<snip>
As for being 'dead' as a hi-fi concept, well (cough, cough) believe it or not Seventh Veil's R & D department are busy working on a high end application even as we speak.![]()
Well just between you and me ...Uncle Ants said:Cool :MILD: Steve. Is this as well as or instead of the "panel speakers" you were prototyping in the kitchen? Are we soon to see a Seventh Veil "Lifestyle" speaker product soon then? All sounds very promising. Don't suppose you can reveal more - industrial secrets and all that ...
7_V said:Well just between you and me ...
<snip>
(You asked)
The Fane MiniPro and MicroPro are also interesting.rick said:i use mission nxt system on my computer. i have to say that for the sum of the parts they are amazing. also fancy a go with a pair of cyrus icons some time in this life.
