Yep, my speaker cables have this feature too:
www.experiencefiltration.com/experience_filtration_005.htm
bob mccluckie said:Err.....
I'm running active with 4X15 metres of speaker cable from amps in one room to speakers in another.
Bob
Paul Ranson said:(BTW what's 'slam' sound like?)
Mmm. I could be wrong here, but I thought electrostatics had transient response like pretty much nothing else on earth (except in the really deep bass obviously), because the diaphragm weighs basically nothing.analoguekid said:Get rid of yer electrostaics and you might find out![]()
PeteH said:Mmm. I could be wrong here, but I thought electrostatics had transient response like pretty much nothing else on earth (except in the really deep bass obviously), because the diaphragm weighs basically nothing.
So you don't use feedback to the far side of the filters?Changing the output inductors has a significant effect on the output impedance.
Paul Ranson said:If you didn't have to meet CE and other regs would you need output inductors on a Class D? Why not use the same argument as the non-OS DAC?
Isaac Sibson said:Not necessarily just caring about the numbers.
During some recent testing with prototypes, we tested several different variations with different measured damping factors, and there was a noticeable difference. Some people preferred the lower damping factor case, I preferred the higher damping factor case as it had greater slam. The change in output impedance between the two cases was around 0.01 ohms.
My speakers are atypical...Paul will lend you his speakers for experimentation.
