Lubricant..
RDD
Longterm Lurker
Cheshire
Hi chaps
My Micromega CDP has been making a quite loud intermittent, but more often than not, squealing noise when the tray ejects for a while now and it's finally started to wind me up (gets to something when the Mrs says "that sounds rough" :D )
I looked at suitable types of grease to oil the cogs so to speak in the past but was amazed at how expensive it was (especially the needle applicator stuff I would need to do an accurate job), I will probably never use it again so really I'm looking for recommendations for some cheap suitable lubricant to stop the tray/cog noise happening....
Some cheap grease should do the job. Silicone or Teflon based probably best as they won't eat any bits of rubber/plastic...
Isaac Sibson said:
Yes, that will do it RDD.
Spot on, thanks, not bad for £3 either, it must have been the needle applicators that were knocking the price up last time I looked :rolleyes:
