mains query...
OK, its pretty well known and I have mentioned it on HFC once :eek:
A 1v dc offset has been festering around for quite a while now, so maybe a diode and cap network (600V min I would recommend) might help here, has a quite pleasant effect, most cost effective too :)
As for the other stuff, maybe as your more open minded that I first thought :eek: perhaps you would like to whitness some first hand :) Wm
1v DC offset? No I haven't looked for that but I shall! :)
Seems a little high, maybe a few hundred millivolts but still sufficient to cause problems for a toroidal transformer. And I do remember seeing a circuit diagram somewhere for an asymmetric DC filter..
Open-minded scepticism is always best. ;) :D
mosfet said:
LE, Have you considered that raising the mains impedance seen by your kit through the use of inductive / capacitive filtering is not necessarily a good idea ââ'¬â€œ this at least is my thinking and the reason I avoid mains filters.
Ahhh 'mosfet', don't start getting me all worried now :p
To be honest, since moving into my current home last July we have been making some pretty drastic modifications to the floor-plan so the audio system has been packed away.
Our home is only about 55 years old but it is still a solid brick home without any stud partitions at all ;) This has made re-wiring quite a challenge. The interesting 'feature' is that it only has one ring-main so to play safe I installed the previously mentioned filter sockets by way of experiment. I wanted to protect all my IT equipment for sure so that was my main reason for installing the filtered sockets, but I thought, prior to actually splitting the ring main let me try a filtered socket at the location where the audio system will sit.
As we just about to have new carpets fitted in the lounge this means that I will be able to run my own little tests to compare the following:
1. With filtered sockets and Eichmann power cable
2. Without filtered sockets and with Eichmann
3. Without any power cable modifications
4. Same as above but post ring-main split
I will have to conduct numerous listening tests (what a shame), but hopefully will be able to come out of it with a sonically pleasing result.
NOTE: Even though we have just one ring-main the local utility checks have verified that we do not actually need to split the ring as the circuit has been modified to current IEE wiring regulations with appropriate RCB's,...or is it RCD's these days?!?!
OK, time to stop rattling on...
When all is said and done this of course is all that matters LE.
Out of interest do you know what's inside the 'blue box' on the Eichmann power cord? The website says there are no current limiting ââ'¬Å"capacitors or other electronic componentsââ'¬Â so perhaps a big whackin ferrite?
Sceptical? When I read phrases like ââ'¬Å"fractal resonance control technologyââ'¬Â what do you expect! :eek: The Eichmann bullet plugs are a rather neat design tho'.
Tony
DC blocking circuit
http://www.sjostromaudio.com/hifi_files/qrp/dct01r0schema_p1.pdf
http://home.swipnet.se/~w-50719/hifi/index.html
Richard,
Fear not built the odd one or 2 in the last few years, but thanks.
Our mains boxs have the ability to screen this too as a matter of coarse.
Prehaps you would be up for a visit maybe with some of your open minded sceptisum? Wm
mosfet said:
Inside the 'blue box' is a specially designed shape of high-damping aluminum alloy inserted within the LIVE conductor of the cable (as per statement on the Eichmann web site), and from talking with Rob Woodland in the past I remember him saying that the design is based on the principle of 'fractal mathematics'.
I am not going to attempt to explain fractals mosfet, my principle at the time was to listen to the explanation provided by the manufacturer, get the sample product, then get it out for test.
While I will admit that I too was skeptical I tested the cable and passed it around to several trade contacts and we all had clearly defined conclusions on the benefits that this power cable provided.
Now, putting this in perspective; I had the cable tested because we were looking to distribute Eichmann products here in the UK and rather than view all their products under the same light as the popular 'bullet plugs', wanted to critically look at each item available. My own Eichmann cable was a free-sample ( ;) ), so I have not bought into any media hype here. All I know is that I have been impressed with the results when I have used it and from other users tests it compares to other similar products in the UK market priced at the same point and up to around £500.
I did not like the rubber mains plug installed on the cable so I contacted the Chinese factory that manufacturers the Clipsal plug (as used by Kimber Cable and Consonance to name but two), and obtained one of their plugs to install. The O/D of the Eichmann cable presented some challenges in installing the Clipsal plug and I had to revert back to the factory who stated to me at the time they would provide an additional cable entry collet/clamp assembly for a larger O/D.
Not sure if this ever happened, I know Rob at Eichmann said he would continue with the rubber plug for the UK market after I had to close down my business due to my health problems. :(
Tony, you have PM.
LE thanks for taking the time to respond.
I don't quite see the connection between fractal mathematics and power cable design ââ'¬â€œ not that I know an awful lot about fractal mathematics other than those infinitely geometric models that fractal equations produce.
Aluminum alloy does indeed have high internal damping owing to low mass and high rigidity so there may be something there that isn't immediately obvious..
But does this mean we can expect loudspeaker cable based on chaos theory any time soon! (remember where you read it first!) :D
Hi P-A
Thanks for making the circuit schematic for the DC trap available.
On a similar point does anyone have any comments on this modification?
ââ'¬Å"I learned about a tweak that allegedly could make some cheap DVD and CD players sound much better: putting two 0.47UF 600V Auricaps across the hot/neutral wires in the power input of the player is supposed to filter all sorts of crud out of the power. Auricaps are pretty expensive, so I tried it first with similar A/C power rated caps, but that didn't do anything noticeable.ââ'¬Â
ââ'¬Å"So I put them [the Auricaps] in (behind the fuse, so they don't fail and catch fire while the unit is unattended), powered up and sat back to listen. It took a while before I was able to lift my jaw off the floor... AMAZING detail, sound stage definition up a full level of magnitude.ââ'¬Â
There's little unusual about placing a capacitor across live and neutral to add some parallel HF filtering ââ'¬â€œ but are Auricaps (or any other high quality metallised polypropylene cap) better than a standard X2 cap in this application or is this wishful audiophile thinking?
Yes I do. People can do what the hell they want to themselves and pay the consequences if sh*t happens, but I wouldnt recommend to anyone else that they start fitting components in the mains that are not designed for the purpose. You have not even told us if the quote refers to 110V acrms or 230 acrms?
Answer yourself this: Can you stand in the witness box, under cross examination, and explain to Judge Judy why you chose to use inappropriate [perhaps illegal, if you were selling it] components? If not, leave the bloody thing alone. Build some bigger speakers
Whooa hold on!!
I'm not recommending this modification to anyone ââ'¬â€œ clearly there are obvious safety implications of using non class X rated caps in this fashion and this I'm patently aware of. Merely I was asking for critique from those who I assumed would already be aware of such considerations.
GrahamC
Go read my contribution to the 'TNT audio powercord' thread before putting your barristers wig on!
