More myths?
Depends on the design of the equipment. The issue with transistors is that they behave differently at different temperatures. This means you need to get any heatsinking up to temperature as well. In the case of the S300 in free air, this takes a couple of days at idle (rather less if you're using the amp of course) because the thermal mass is huge and the heatsinking is efficient. However, if you're giving the amp some stick then you'll get the internal device temperatures up pretty fast... no more than 30 mins or so.
It is necessary to differentiate idle warmup versus use warmup. Idle warmup is slow (except with class A), whereas use warmup is much faster.
cars take a while to warm up before they perform at their best, so why not electrical equipment?
actually,its the oil that needs to warm up,and you simply can't compare the 2,its just not a valid comparison
I didnt', someone else did!! Its not just the oil, the water, too for your heater :D and it does have an operating temp. for vapourisation and flame spreading of the petrol/air mixture...there's a lot to it....wm knows!!
I know there is a lot to it,but i still can't see how a frigging gurt turbo warming up has any relevance to HIFI! :)
There clearly are measurable differences between cold and warm electronics, and it's of course a fundamental physical principle that as the temperature increases the conductivity goes down in conductors and up in semiconductors.
However, there are clearly measurable differences between cables too. :) I suppose it's conceivable that the difference is sometimes audible in some kit, but I can't honestly say I've ever noticed it. The whole warm-up phenomenon is an obvious candidate for the power of placebo (how come cold electronics are never reported to give a 'warm' sound?)
Lt Cdr Data said:
Cars take a while to warm up because they start cold and heat engines work best at a particular temp., which is attained by burning the fuel and cooling to keep it correct.
Electronics doesn't.
Interesting comment, but who says?
For a car, then I'm guessing the manufacturer would.
So what if an amplifier manufacturer recommended warm up, wouldn't that be the same principle?
i for one know that every bit of kit i have ever owned (and there has been a lot) has allways sounded better when warmed up. valve stuff NEEDS warming up period but speakers being mechanical also work better after they have been playing for a while how do i know this? well it's not 20 odd years working with electricity or the knowledge of my farther (who was a leader in his field of electricity for nearly 45 years) it's my ears friends my ears. BTW my Tri Vista Needs warming up
one more thing - never mind the system warming up - what about you..?
I find a big spliff helps me...the music does sound better after a nice reliefer... :MILD:
zanash said:
Incidentally the cost is pence per day or less, just think how much it cost to run a freeze 24/7. I'm prepared to pay the small ammount to have instant beautiful music!
It must be good to be ignorant sometimes. The maths is so easy if you are keen to know. However, even if I suspect the final figure will shock you it would not really change the mind of those who feel they must keep them warm up all the time to feel like a proper audiophile. :p
Something aside from "warm-up" to think about is that failures seem to occur more often at switch-on rather than left-on.
I don't leave mine on (Auntie is very eco-conscious) even though I do think my amp benefits from a bit of a warm up, but this point about failures being more comon if switched on or off is true of pooters in my experience, so I suspect probably true of other electrical/electronic bobbins too.
Consider it another way.
From the recent poll, a good deal of the people on this forum had systems with RRPs over £10k. For many, a regular upgrade is not uncommon (certainly so if you're name starts with Mer and ends in Lin).
Even if the system used 100% of the electricity usage in a house, do you really think many of us would give a stuff? Just think of the ratio of electricity costs vs the cost of the system and software running on it.
Valve or turntable users, probably spend more a year (on average) on valves and cartridges.
I am also one of this people with systems with an outrageously retail price tag. I have listen to my toys, done the sum.
As I have mentioned above I certainly don't think some would think twice whatever the cost, when they are told there might be a remote possibility that it could provide that illusive IMPROVEMENT to our toys. Many of us are told we have to buy toys as long as it appears to sounds superior is enough justification even if it is simply just an figment of your imagination. What chance there is to try to have a logical discussion of economy and saving the planet?
