Musicraft (Derby) - Clearance + Special Offers
Yamaha RX-V675 AV receiver (DISPLAY UNIT - NOT USED) in Black finish RRP £500_____Was £325_____Now £300 is provisionally sold
***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Btw, Monitor Audio Radius R250HD (demo/display) - speaker only - in Piano Black finish RRP £275_____Now £110
***** Please call before travelling *****
Thanks
Rick @ Musicraft
Anthem MRX 300 AV receiver (demo/display unit) in Black finish is SOLD
Thanks
Rick @ Musicraft
Clearance/Special Offers list - Price update - Naim SuperUniti All in One Player (demo/display unit) in Black finish RRP £3490 _____Was £2750_____Now £2500
Thanks
Rick @ Musicraft
Clearance/Special Offers list updated to include Yamaha CX-A5000 AV Processor (demo/display unit) in Black finish RRP £2500_____Now £1875
http://uk.yamaha.com/en/products/audio-visual/av-receivers-amps/cx-a5000_g/?mode=model
Thanks
Rick @ Musicraft
Plinius Hiato amplifier (demo/display unit) in Black finish is SOLD
***** Musidraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
Monitor Audio Radius R250HD (demo/display) - speaker only - in Piano Black is SOLD
Btw, Chord Electronics QBD76 DAC (demo/display unit) in Brilliant Silver finish RRP £4140_____Now £2500
Thanks
Rick @ Musicraft
Thanks
Rick @ Musicraft
Plinius Hautonga amplifier (demo/display unit) in Silver finish RRP is SOLD
Thanks
Rick @ Musicraft
Clearance/Special Offer list updated to include - Monitor Audio Platinum PL300 speakers (demo/display pair) in Rosewood finish RRP £6500_____Now £3799
Thanks
Rick @ Musicraft
Clearance/Special Offers - Price update - Yamaha RX-A3030 AV receiver (demo/display unit) in Black finish RRP £2000_____Was £1250_____Now £1000
Thanks
Rick @ Musicraft
Naim SuperUniti All in One Player (demo/display unit) in Black finish RRP £3490 _____Was £2750_____Now £2500 is provisionally sold
Thanks
Rick @ Musicraft
Monitor Audio GX300 speakers (demo/display pair - speakers only) in Gloss Black finish RRP £3000_____Now £2000 are provisionally sold
Thanks
Rick @ Musicraft
Clearance/Special Offers list updated to include -
Hegel H160 AMP/DAC + Monitor Audio Silver 10 speakers (Black Oak, Natural Oak, Rosenut or Walnut) Special Package Offer (ALL NEW)
(http://www.hegel.com/images/reviews/H160hifiplusuk.pdf - Hi-Fi Plus Hegel H160 review)
Hegel H160 AMP/DAC + Monitor Audio Silver 10 speakers (Gloss Black or Gloss White) Special Package Offer (ALL NEW)
The H160 amplifier has one purpose, and one purpose only - to allow you to connect whatever device you want and make it sound as good as it possibly can. First of all, we designed an integrated amplifier with a broader set of connections than any other amplifier on the market, in this category. There is a wide variety of connections, varying from classic balanced and unbalanced analog connections, to Home Theatre integration and onwards to various digital inputs. You can also stream wireless music to it from devices with Apple AirPlay or DLNA. Secondly, we realized that not all the devices you choose to connect are designed to be high-end music performers. This meant we had to develop a range of unique technologies and implementations to make certain that your phone, tablet or CD-player could reach its fullest potential. The H160 incorporates technology that "repairs" some of the damaged caused by a low quality source.
Finally, we integrated the new with the classic, and included our award-winning and worldwide patent holding amplifier technology, the SoundEngine. This amplifier design completely turns ordinary amplifier designs upside down. The result is a purer and smoother sound with low distortion, as well as ultra dynamic bass due to a high damping factor. And yes, you can also use your headphones, and it uses up to 60% less power than an ordinary amplifier. So, what are you standing there thinking about?
Technical Details
Power output spk: 150 w/pc into 8 Ohms, 250 w/pc into 4 Ohms
Power output hp: 270 mw/pc into 4 Ohms
Analog inputs: 1 balanced (XLR), 1 unbalanced (RCA), 1 home theatre
Analog outputs: 1 fixed line level (RCA), 1 variable line level (RCA)
Digital inputs: 1 coaxial, 3 optical, 1 USB, 1 ethernet (RJ45)
Headphone output: 6,3 mm Jack (front)
Frequency response: 5Hz-100kHz
Signal-to-noise ratio: More than 100dB
Crosstalk: Less than -100dB
Distortion: 0.005% @ 50W 8 Ohms 1kHz
Intermodulation: Less than 0.01% (19kHz + 20kHz)
Damping factor: More than 1000 (main power output stage)
Dimensions/weight: 12cm x 43cm x 41cm (HxWxD)/19kg (shipping)
Dimensions/weight: 4,7" x 16.93" x 16.15" (HxBxD)/42lbs (shipping)
http://www.hegel.com/products/integrated/h160#prettyPhoto
Hegel SoundEngine Technology
http://www.hegel.com/technology/soundengine
http://www.hegel.com/images/reviews/H160hifichoiceuk.pdf
Hi-Fi Choice H160 review
Silver 10 is a completely new model introduction, comprising a three-way configuration in a large floor-standing tower system. Equipped to energise the largest of rooms with naturally explicit wideband audio from music and film sources.
- Improved C-CAM® (Ceramic-Coated Aluminium/Magnesium) gold dome tweeter design with damped rear chamber and innovative dome venting technique for improved clarity and wider operating bandwidth.
- Specially developed 4" mid-range driver with 'under-hung' voice coil and motor system. The voice coil remains in the magnetic gap ensuring very low distortion - better damping and improved mid-range clarity.
- Dual 8" bass drivers featuring concave 'dished' C-CAM cone profile
- RST® (Rigid Surface Technology) cone profile, for improved diaphragm rigidity and reduced distortion.
- Three-way configuration allows drivers to be optimised to deliver better overall performance.
- Improved cast polymer bass chassis design for better rigidity and reduced reflections.
- HiVe®II port technology delivers smoother airflow for better transient response and tighter bass.
- Single bolt through driver systems for increased overall bracing, rigidity and driver/baffle de-coupling.
- Pureflow® Silver plated OFC copper internal cabling.
- High quality crossovers with premium grade polypropylene film capacitors.
- Available in selected premium quality wood veneers or high gloss finishes.
- Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity and low cabinet colouration.
- Invisible magnetic grille fixing provides clean visual styling when the grille is off.
- Terminal panel at floor level for easy cable connection.
http://www.monitoraudio.co.uk/products/silver/silver-10
Thanks
Rick @ Musicraft
Clearance/Special Offers list updated to include Monitor Audio GXFX speakers (demo display pair - speakers only) in Piano Black finish RRP £1400_____Now £700
Thanks
Rick @ Musicraft
Clearance/Special Offers list updated to include Monitor Audio GX100 speakers (demo/display pair) in Dark Walnut finish RRP £1250_____Now £729
Thanks
Rick @ Musicraft
Clearance/Special Offers list updated to include Plinius Odean 6 x 200w multi channel power amplifier (demo/display unit) in Silver finish RRP £11500_____Now £5750
When released at CES Las Vegas the Odeon stole the show. Big and beautiful, this unit is not something you hide away in a cabinet.
Designed to respond to a demand from the home theatre community for something that was as beautiful as many of the shows and musical arrangements the movie industry produces this product introduced the rounded profile to the company's chassis designs that is now copied by so many of our peers.
If you want to experience the sheer excitement and exuberance of a movie like Chicago, or the dark threatening mood of the Lord of the Rings Trilogy you can't beat having the Odeon in your home theatre system.
Thanks
Rick @ Musicraft
Clearance/Special Offers list updated to include Monitor Audio GXC150 center speaker in (demo/display unit) in Piano Black finish RRP £650_____Now £375
Thanks
Rick @ Musicraft
Yamaha RX-A3030 AV receiver (demo/display unit) in Black finish RRP £2000_____Was £1250_____Was £1000_____Now £700 is provisionally sold
***** Musicraft website - Special Offers list http://ww.musicraft.co.uk/special-offers/ *****
***** https://www.facebook.com/MusicraftUK *****
Thanks
Rick @ Musicraft
Clearance/Special Offers list updated to include Naim NAP 250.2 power amplifier (demo/display unit) in Black finish -
Thanks
Rick @ Musicraft
