Hi Shrink,
You've got a good point. Although I would say that it does partly depend what you define as midrange. Tweeters still do a lot of midrange work, especially if they have a low crossover point, say 1-2KHz. Or you could even be using a 3-way speaker but still bi-amping with mid/tweet on one amp and bass on another.
This is exactly why I didn't think of your above point. I wouldn't use the same amps on bass and treble duties if I had much choice about it. In my mind half the point of bi-amping is to specify your amps for the required job. I'd want massive raw power for the bass, and refined delicacy for the tweeters.
Unless the bottom amp was substantially larger and better endowed than the treble amp, your likely to compromise.
