Perreaux
Hi Penance,
Mullard tubes are apparently a very well recommended tube for the X-Can V2, and are apparently about £30 a pair. The stock Philips tubes are somewhat bright and forward, and Mullard tubes apparently give the sound a more rich and detailed feel.
Valve amps are said to be the best match for the Sony headphones I've got, hence my decision to go for the X-Can as a cheap, tweakable and surprisingly potent (particularly when modded) amplifier.
Now, where is WM with his suggestions... :D
Originally posted by PBirkett
Hi Penance,
Hi Paul
I usually find my self with military spec Philips ECC83's because I like the detailed slightly forward sound they give.
If you want a slightly warmer sound, slightly less forward mullards will give you that, amongst others. Try speaking to Jim Fish at Wilson Valves. Hes a really nice bloke, and reasonably cheap too.
NB I pay about £7+vat for a phillips, mullards are about double that.
NNB Watch out for mullards ''in disguise'' i.e. with a different code on them. I recently picked up a Mullard GZ32 (usually about £25 + VAT) for £10 + VAT (from Jim as it happens) because it had a different label and coding on the front.
NNNB! Nice people like 'langrex supplies' or 'wilson valves' or 'CVC' to a lesser extent will happily tell you if they have any valves 'in disguise' as I like to think of them!
...sorry about the thread hi-jack, you can have it back now....
Chris
The stock valves are Philips, bottleneck, but I am not sure what model they are, but they are quite forward sounding, and I have to say I quite like that, I'd like a valve that is better, but more or less retains the original character, or perhaps the stock tubes are good enough?
Maybe I just need to change the CAPS and sort the power supply, hmm, decisions decisions :D
