Rega + Reviews - At Musicraft (Derby)
Rega launches their new RP6 turntable
http://www.whathifi.com/news/rega-launches-rp6-turntable-and-apollo-r-cd-player#comment-2678207
RRP £798 or £998 (with Rega's Exact cartridge)
Exact
Output: 6.8 - 7.2mV
Stylus: Vital. Complex fine line micro-ground from a rectangular diamond billet.
Fixing: Rega three point fixing
Coils: High Spec parallel wound coils
Colour: Yellow
All Rega cartridges play at 1.75g
Thanks
Rick @ Musicraft
Rega's new EAR headphone amplifier
EAR
New Design
Developed by our engineers the new Ear benefits from a completely new surface mount PCB layout based on the hugely successful Brio-R amplifier. Exceptional performance is guaranteed with the convenience of independent mute, volume control and multiple connectivity options to integrate perfectly into any users system.
Power supplies & Noise Reduction
The Ear pushes the Brio-R power amplifier circuit concept to a new level with the use of a low noise fully regulated supply. Noise has also been kept to a minimum by the use of an external mains transformer. The Ear exceeds the voltage requirements of IEC 268-15. This along with low output impedance makes it suitable for studio use as well as a hi-fi headphoneamplifier. The Ear operates in Class A at normal listening levels.
High Quality Components
The Ear utilises the highest quality components and our engineers experience to achieve the best sonic performance. Utilising the design ideals of the 'cascaded emitter follower output stage' with a pair of complementary Darlington output transistors, along with Polyester film and Nichicon FG capacitors in critical positions ensures it is our most advanced performing headphone amplifier to date.
Custom Case
Housed in a compact custom case the Ear is designed to match the current range of Rega electronics with a matching high gloss front facia.
The new Ear Headphone Amplifier benefits from an all new extruded aluminium case and new styling giving it more of a family feel to match its illustrious big brothers.
The Ear simply connects to the tape output of an amplifier via phono leads, the headphones are plugged into the front panel and there is a link socket incase you need your tape output sockets for other use.
The new Ear is also available in our new alloy finish.
Features...
Specifications
Maximum output level
25W load 775mW
32W load 685mW
50W load 530mW
100W load 320mW
600W load 60mW
Open circuit voltage 6V
Input impedance 20KW
Gain 28dB
Frequency response 12Hz to 37KHz
THD typically 0.003%
Signal to noise ratio referenced to max output level -100dB (22Hz – 22KHz)
Maximum Power requirements
24VAC at 225mA (685mW 32W)
Dimensions: 178mm Wide / 155mm Depth / 45mm Height
Finishes available:
Silver satin metal finish
Black satin metal finish
RRP £198
***** Musicraft - Clearance + Special Offers list https://www.audio-forums.com/as-rediect/showthread.php?t=28303 *****
Thanks
Rick @ Musicraft
Rega's new Fono mini A2D moving magnet disc stage with analogue to digital conversion.
The Rega Fono mini A2D is a quality phono pre amplifier.
The Fono mini A2D is designed to amplify the signal from a moving magnet cartridge to a suitable level for all line level inputs of an audio amplifier. The USB interface also offers the ability to simply transfer vinyl to PC .
The Fono mini A2D amplifier offers exceptional performance and convenience and will be a valuable addition to any Hi-Fi set up.
The new Fono mini A2D benefits from an extruded aluminium case and very user friendly front and back panels that make this phono pre amplifier a very easy product to use.
To transfer vinyl to your PC You will need to install a digital audio editor. Such software is widely available as a free download (such as Audacity) from the internet. This is a simple interface which allows monitoring of volume and balance whilst transferring your audio to your PC hard drive.
Audio editing software includes a level meter which indicates the output level achieved when playing a piece of vinyl. You should adjust the output as necessary via the 'Level' control located on the front panel. Always take special note of record levels to ensure optimum recording quality.
This is a cost affective version of the MM Fono and based on the phono amplifier as used in the Mira amplifier.
Simply switch on, sit back and enjoy!
RRP £85
Thanks
Rick @ Musicraft
