Room Acoustics
mosfet,
you're right.
I think there is again quite a confusion. While bookshelves and paintings/pictures help the diffusion, carpets are known by the amateurs to be effective as absorbers.
What I feel is rediculous are the words "is as effective as anything else." and "Persian carpets and the like are ideal".
This is just like saying that choosing any two loudspeakers from a catalgue with tha same amount of drivers is the same and if there are 3 drivers in a loudspeaker then it is ideal. :rolleyes:
mosfet said:
...Bookshelves will reflect and scatter far more than they will absorb. To absorb a material needs to be both acoustically transparent (such that energy can pass through) and complex (such that energy is lost as heat). Open cell polyurethane foam, mineral wool and fibreglass have these characteristics.
But it doesn't stop there. To absorb efficiently the material needs to be at least as deep as the quarter wavelength of a given frequency (and ideally it's three quarter wavelength also) since this is where wavelength velocity is greatest. In the case of 100Hz the quarter wavelength alone is about 35ââ'¬Â!
So the Persian rug also, while able to absorb shorter wavelengths, is going to be unabsorptive at anything much below mid-frequencies.
I must apologize for not having been clearer in my post. I'll try to sort out the confusion.
When I talked about bookshelves, Persian Carpets, and 'the mirror technique', I was referring only to the mid and high frequencies. I had already discussed dealing with bass frequencies by 1. positioning, 2. bass traps and 3. equalization.
Of course a Persian rug would be virtually unabsorptive at anything much below mid frequencies (in fact, it wouldn't be much use with the lower mid frequencies either). Mounting the rug on a sheet of polyethylene (or similar) 1" or 2" thick, can reduce the frequency at which it's effective.
If the room is acoustically hard, it's often because it has a lot of glass and/or concrete. Bookshelves are considerably less reflective than the concrete walls that they are mounted on and I have found them to be highly effective in mitigating the effects of an acoustically hard room.
titian said:
...What I feel is rediculous are the words "is as effective as anything else." and "Persian carpets and the like are ideal".
Again sorry for the confusion. This should be taken in the context of the rest of my post.
Of course I didn't mean that the bookshelves, paintings or rugs were as effective absorbers as anything else. I said this in the context of my views on the brain automatically compensating for moderate acoustic differences between rooms (except in the bass frequencies). This compensation means that full acoustic treatment for the mid and high frequencies is undesirable in my opinion as it gives an unnatural feel to the room.
In this context, bookshelves and paintings are as effective as anything else, for improving the acoustics of a hard room, in my view, while Persian carpets are ideal.
I hope that this clarifies my comments.
titian said:
Please tell me how technically your speakers can minimize the negative effects of floor and ceiling reflections.
The Nonsuch 4s are designed with a small vertical array drive unit. This is over 20cm high but only 5cm wide. Thus, while horizontal dispersion is similar to many conventional loudspeakers, off-axis vertical dispersion is reduced. There is a considerable vertical sweet spot which makes these 'sit down' speakers. You have to listen on axis to hear the full frequency response. Stand up and you'll lose the high frequencies, while at floor or ceiling level the mid and high frequencies are considerably reduced relative to the lower frequencies.
One benefit of this approach is that the negative effects of the early floor and ceiling reflections are minimised.
Perhaps we're splitting hairs here Steve.
If your point is that absorption is not desirable at mid to high frequencies (in a hi-fi context) rather diffusion is preferable and bookshelves are as ââ'¬Å"effective as anything elseââ'¬Â then I'm in agreement ââ'¬â€œ see my post at the top of this page.
Incidentally have you tried any of the Fostex full-range drivers and how do they compare to the Bandor units? I've been toying with idea of building some open baffle full-range speakers (without too much expenditure) but need to do a little more research first.
No, I haven't had any experience with the Fostex drivers so I can't say how they compare with Bandors.
I'm very keen on the open baffle approach but would need to high-pass filter if I tried it with the Bandors, in order to keep the cone excursion down (they're only 2" diameter). Might be interesting from about 150Hz up though with a matching dipole bass.
Have you visited Linkwitz's web site? He's a top designer and the site's well worth a visit.
PS: I've read your post at the top of the page and I'd say we're in broad agreement on the room thing.
