Royd Revelation
Originally posted by lowrider
If they must be close, then point them forward, instead of towards you...
I would disagree with that :rolleyes: I have mine quite close (about 2m away) and also only barely behind my listening postition so I have them facing each other, rather than facing the fronts. I think facing the fronts is better in a setup like yours where they are much further behind you.
In setting the relative volume levels an SPL meter is really useful. I had done mine 'by ear' but when I then re did them with an SPL meter the rears were completely wrong :eek:
Mine are completely wrong too, because I set them up for DPLII by ear, and I know they are higher then the fronts...
Your case is a bit different from most people that have them close because they sit against the back wall, and thats why I sujested pointing them forward, but the main poinrt is not to point them to our ears when they are close...
Are you sure you read my message? You wouldn't have come to that conclusion based upon my advice.
Hi Mike
Understood your advice - thx again :D Minstrels are more convenient and because you didn't say NO then I took that as a YES :D
I'm perfectly willing to compromise the HT system as it's in the lounge and I've taken over another room in the house for a music room.
I will try to move them away from the sitting position though.
Jay
