SE W960i
MO!
MOnkey`ead!
Anyone else using one or any experience?
Loving it in some ways, but seems a bit backwards in others.
Main issues so far are how do I find photo's/video's taken with the camera? Other than by opening the camera and then going to view I can't find a way to just open up the folder or such???
Also, when tryin to connect to my wireless router, I'm asked to enter my wep key. My key is about 60+ random characters long and I'm unable to enter it all into the phone. I get about half way and it wont allow me to enter anymore characters.
Not used the phone, but on the network side WEP is pretty rubbish security (easily cracked now), so WPA is better, and will be better even with a short Pre-Shared Key (PSK). And it's easier to input. (But does your phone support it? Not sure.)
Oh and you're probably using 256-bit WEP (58 chars) while the phone only does 128-bit (26 chars), I presume, so you need to do something about your wireless settings anyway.
