SonicT for sale
I know what I'm doing ....it corresponds with other peoples definitions of the terms used.
I can't help if you use different terms.
The only part I felt was wrong ...reffering to what I was doing was when you started to talk about bridging and inverting input ...which is not what I'm doing .....Ok so far ?
I'm Biamping its like biwiring in that you need to biwire first, then take it a stage further as you power each drive unit using a single channel. If you need to invert a channel your bridging which is very different, and you can't power each drive unit seperately.
I think we're in agreement. I described how most amps are converted from 'stereo' operation to 'monoblock' operation (ie. by bridging). I wasn't describing how you had configured your equipment. I knew that wasn't what you were doing (both because that wasn't the way you'd described it, and because you can't with the SonicT)
I was just trying to clarify the comments made between Rory and Mr_Sukebe
Agreed. And to be pedantic, you're vertical biamping instead of horizontal biamping.
Biamping, biwiring, verticaly or horizontally, bridged, in phase, out of phase; two amps or four amps?
Thanks guys for explaining but as Zanash mentions, different people use / are using different terms, to describe probably the same circuit.
Remembering that a picture can be worth a thousand words ... ...
Would it be possible for someone to post a few simple diagrams suitably captioned and showing which wire is positive and which is negative? And maybe also what benefits there are be gained by using a particular form of wiring to get the signal from amplifier(s) to loudspeaker(s)
I can but I can work out how to
1/ remove a pic to make more room in the personal space allocation
2/ you could email me and I'll do you some .
