sound downgrade
ErikfH said:
Yes, but Dyn's present a though load and sound quality of this brand ('harsh and forward') is IME related to level of control (power and current). If forwardness is a treat of the amp then it should be changed, if not then the Dyn's need (even) more control.
Measurements specify 250W at@4 ohm vs 400W peak delivery. Dyn's dyp below 4 ohm within the first 200 Hz, and the millsecond duration of the peak might not be able to handle that. Which of course doesn't make it a weak amp, to the contrary, but it might not be enough in certain circumstances (e.g. for difficult rooms)
As a long time Dyn owner and after several (and more :( ) amp upgrades I just recommend to try a (even) more powerful amp and see what happens before looking into other solutions.
i listened to krell 2250 and it had better slam and control at low and allittle more warm but it's sound is quite like 300il but i'm not sure krell 2k power supply will lose the sound in long term or no?!
some tell me ML NO.383 is better choice because krell problem come from it's cheap power supply
Erik - dont you mean more current and load tolerence rather than power then?
If you tried the 2250 and it didn't make much of a difference then its difficult to advise that such upgrade would cause a (long term) improvement.
Yes to me this is the krell house sound - its distortion signature. Try another amp.
If power refers to Watts only, indeed. But apart from tube amps and class A amps, watts and current specs usually increase commensurately if I've understood well.
Or voltage ;-)
What i am saying is that current is the important factor really. Splitting hairs I know but high power is not necessarily required - though it is very likely.
Or voltage ;-)
What would be the advantage of higher power/more watts if the current/voltage remains unchanged?
As you see, I don't even know what I'm talking about all the time :rolleyes: .
Doesn't the current do all the hard work when the loads get tricky? A bit like using a big 6 litre car engine going up a hill - it'll be smoother than a 1.4 model, due to the extra torque?
