The Devil
IHTFP
Wow, Tenson, you truly have the "Golden Ears". Warmest Congratulations!!!!!!!!!!!!!! Sincerely, mind-you!!!!!!
3DSonics said:The perception of a given steady state tone (the current measure of audibility in a physiological sense)
is completely invalid as principle measure of audibility, EXCEPT for steady state tones.
The human auditory system is a mixture of a very unsophisticated and binary "bare" detection system (the ear - with 30+% THD @ 92db build in mechanically, using a very basic purely binary detection) with a purely "analogue computing" copmplex DSP system (parts of the brain) with a slow feedback loop (learning) build in.
To make predictions about what system 2 is capable of by evaluating system 1 is as accurate as comparing the military merit or not of a nuke vs. a crossbow on portability.....
oedipus said:Whoa, that's not the only experiment that has been conducted....
oedipus said:If you can provide an experiment which invalidates the data gathered using tones then a large number of people would find that interesting. Do you have such an experiment? I'm guessing "no" is the answer.
Are you sure about that? It sounds somewhat unlikely given the wavelengths of sound in air at 7Hz (and even less likely in tissue).brizonbiovizier said:It resonates the internal chest cavity and standing waves destroy the internal organs.
This sounds more likely... i.e. simple vibration is the issue rather than any resonance/standing waves. Although if there is one particular frequency that is more dangerous that would suggest some sort of resonant process...The Devil said:I think it vibrates certain internal organs to bits.
Shockwaves??? In the body at 7Hz??? I'm going to have to look into this properly...brizonbiovizier said:Just googled online to check - its between 6-8 Hz and is due to chest cavity resonance causing pressure shockwaves. Vibrating organs to bits occurs at much higher frequency.
