I have wanted to build some big Tannoy cabinets myself for ages but never had the time. I noticed Dev had built some bigger cabs for his DMT 15 drivers so I contacted him on the off chance that he might want to sell these. He very kindly gave them to me for nothing and I've been experimenting for the past few months.
I have DMT12 Mk1s and i12s and both driver types fit the cabinet perfectly. I think both these and Dev's CPA12 drivers all use the same cast chassis. I used the DMT 12 drivers as they sound by far the best to me.
The balance between the drivers varies a lot depending on loading. With the cabs sealed as Dev made them, LF is much quieter than in the original ported cabs. Ported, the bass is a lot louder than the originals. As I don't have the skills to redesign the passive crossover and I already had 2 power amps and an active crossover, I decided to use them active so I could get a reasonable balance between the LF and HF drivers. I also experimented with a parametric equaliser.
Initially, I tried them sealed but with both my drivers, they sounded quite uninspiring - lacking much bass at all. I then tried them with the rear connection panel removed to act as a rudimentary port and this time there was loads of uncontrolled bass. I stuffed some old t-shirts in the holes and I managed to get a decent quantity of bass that was quite well controlled, so I decided to add some proper ports. I think I tuned them to about 40Hz as this is the -3dB point of the DMT12s and I assume the driver wouldn't be happy being asked to go lower.
Anyway, I've had a lot of fun but I feel I would need to tinker a lot longer to get the balance just right and the original cabinets are a better size for my room so I've decided to let them go. If anyone would like them, please get in touch. They are very heavy and big - they only just fitted in the back of my largish estate car. They are 108h x 50d x 45w cm. I live in Chelmsford, Essex.
