top quality music sub
Gotta agree about sealed cabs being more accurate and controlled bass in a smaller room.
Sorry dude though you were taking the p*ss. Have avatars switched off and forgot all about it.
Post edited
If you have eq would it matter if the sub was ported or sealed so much?
I used a sealed 8" in my car, due to the low end cabin gain you get in a small space. This keeps things more linear. Although I thought a larger space like a room might be much more forgiving?
If you have EQ and can take meaningful measurements then yes, you can go sealed and still get deep bass. Thats something I have done. But you need a woofer with good thermal power handling (so the voice coil doesn't burn out) and a load of power.
The woofer can go as deep and loud in a sealed box as a ported one, provided the voice coil and the amps can deal with the power required to do so.
