Video Squeezebox
Thinking of setting up an LCD TV in the bedroom...
Is anyone here using a device that streams video around a home ethernet similar to what Squeezebox does for audio?
I imagine a remote controlled "decoder" that goes in the viewing room with a Cat 5 input. It takes the TCP/IP encoded video off the network and outputs it to component video (or DVI) for input to an LCD screen.
There would be some software on the source computer that allows you to insert a DVD and it can be controlled remotely from the viewing room.
I haven't done any Googling yet so any pointers would be appreciated.
There's one called the NAD Netcap. It was announced some time ago, but not seen it in stock anywhere.
I'm not sure but a thing called a Slingbox might do what you want if you have a wireless network at home.
Apple are coming out with iTV Jan next year, stream itunes, and video to your TV, about £150
Slingbox is ethernet only, you'll need a wireless bridge.
They have just brought out a few new models.
You also would need some sort of PC in the bedroom,
