penance said:I think Rega just dont place much importance on it. They will supply spacing washers to use if your putting an RB on a different deck etc. If you want VTA then you need to look at aftermarket supplies.
His claims to manufacturer independance are hardly bolstered by glowing eulogies about Nordost products in almost every issue. The latest (issue 35) was a case in point. Four pages about how marvellous the new Nordost Thor distribution block is followed only 10 pages further on by a double page spread Nordost advert for, guess what, their new distribution block, complete with a glowing quote by RG from the very same review 10 pages earlier. Then the inside back cover is another Nordost advert for their mains cables, also mentioned in the review. RG doesn't even hide the fact that his system is fully Valhalla'd up, now with 2 disti blocks at £1600 each. One wonders how he can afford all that very expensive cabling. On the other hand perhaps he doesn't have to afford itmerlin said:RG seems to be getting a lot of flack these days![]()
How the hell can he run a magazine without disclosing the commercial interests of the writers?
zanash said:Gawd sake .....anyone who has set up a TT will have heard the effects of VTA. Heres a little test lower the height of your arm, this changes the VTA and listen to the effects, now raise the arm height and listen again. The effects I hear are muffled and treble light, and toppy and bass light I'll not say which incase any one wants to give it a go. Once you have the angle set right you get a balance frequence response.
