Dev said:
Guys, if you are going to quote me, at least use the whole sentence, :grrr: like Bub did.
"Strange that you listen to rhythm when classical music doesn't have it." is not the same as "Strange that you listen to rhythm when classical music doesn't have it, at least in the repetitive way that pop does."
Well, not quite, no, but the way you've used a comma and the words "at least" mean that your qualification is rather weak, ie. that you're giving the impression that you essentially stand by the original statement.
I think the most interesting thing that happens the odd time threads of this nature come up is the negative reaction you get in some quarters. It appears that to some people music is a fragile kind of magic which will stop working if you try to ask too many questions about it - hence the resistance to any kind of analytical understanding of what is going on.
To clarify and expand on my earlier statement, namely that harmony and structure are what makes music interesting, even at the expense of rhythm and melody. It should be obvious that different music appeals in different ways and makes different demands upon the listener. The example of
Jupiter which has been brought up here is a case where the irresistible onward rhythmic drive provides a lot of the attraction (and
Uranus even more so), and then of course there's the "big tune" in the middle; yet without the exuberant, brightly primary-coloured harmony in the outer sections, or the rich, noble restraint of the harmony in the middle bit, the music would be lost altogether. And when we move forward to
Saturn (my favourite of the
Planets FWIW), we find another of those streamlined exercises in harmony I was talking about earlier - very little melody to speak of, and simple, slow pounding rhythms for the most part, but the harmonic progression gives an inevitable, inexorable sense of forward motion all the same.
Or to look at it another way, compare the Scissor Sisters' weird version of
Comfortably Numb with the Pink Floyd original - very little melody to speak of, and the Bee Gees-esque disco rhythm certainly wasn't there when Waters and co did it, but it's still unmistakably the same song because of the characteristic chord sequence.
There's plenty of visceral, elementally kinetic music where the rhythm assumes a very important role - Bartok would be the exemplary case, though for example a lot of Bach has the same earthy, physical feel to it - but without the harmonic and structural elements the music would have no onward drive or sense of progression.
Edit: oops, hit "submit" before I'd finished
