Windows Media player
Manchester, England
Hello
Im having more than a few problems with Window Media Player...
When i'm trying to copy a CD to the Hard drive WMP hangs... It does this every time without fail... Why is this?
I-tunes or CDex it work Perfectly..
You may ask why dont i just use the packages that work... well i need to use the 192Kbs WMA format to transfer to the Xbox :D
If you have anyother software suggestions, that would be great.
Thanks in advance
Chris
I think Roxio will do WMA format. I only got it a few days ago but I can check this evening if you want to know.
Originally posted by PBirkett
Does the X-box not support MP3 then? Skanky gits!
Not out of the Box... you need another bit of software called Music Mixer to transfer the MP3 or WMA from the PC to the XBOX (£20) . Then to make the tunes compatable with the ingame soundtrack you then need to convert them again which takes aaaaaggggeeeessssss.
Chris
