£600 stereo power amps.
If 5 channels would do, the Linn AV5125 gives a compact, quiet and cool-running solution, excellent sound, good value iin relation to other Linn products IMHO.
The Linn is a good shout. Obviously a 2nd Bryston or Belcanto 5 channel power amp would be good too.
Others to consider - Rotel RMB1095 (hugely powerfull 5x200 watts), Parasound HCA2205 (even more powerfull - 5x220). Both should be available ex-dem for £1800 or less.
There's also a Tag 5x100 power amp on ebay at the moment - it had some criticism at the £2.5K or so it was selling for new but the one on ebay was well under £1K when I was it yesterday.
There are various others - Primare, Copland, Myryad, Roksan etc that might be worth checking out.
I'd tend to go for a multi channel power amp rather than 3 stereo ones just for the neatness really - but that's just me.
Matt.
Good morning everyone.
Some very good suggestions, thanks for your help on this one.
I have heard a Bryston 9B ST, which i thought was very good.
I shall look up the Bel Canto design.
Lots of homework to do for me over the weekend:)
Appreciate your time.
Viper
I also did stick with 5.1, 6.1 is an overkill, unnecessary in a normal living room, IMHO... :rolleyes:
It also depends on wich speakers you have, some are hard to drive, some easy, I have all Bryston, 250 watts for the front pair, 120 watts for center and surrounds... :MILD:
A second hand Meridian 558 5 channel is a beast of an amp - if you can find one. I bought one a week or so back from hififorsale.com for 1800 quid, spot on the budget.
Prior to that I was running Tag 125M monoblocs for my front speakers and then Tag 100P's for the center (bi-amp) and rears. Worked a treat and would easily kick the Tag 5channel into touch. - second hand/ex-dem you should easily do something like that for under 1800 quid.
