Hi WM,
"That be the fellow, Pretty sure he ran an adaptive set on his car, I seem to remember a 'hoo har' over its use at prescott a fair few seasons back.
He used to work at Benetton I think?"
He did work at Benetton, then Ferrari and then BAR. But he didn't run any form of active or adaptive suspension. He put LVDTs on the the suspension and a range of other sensors on the car that most likely no-one else had done in hill climbing. Logged all that data in a data logger so that he could develop the car further.
"The active suspension, when working correctly could produce some quite remarkable results, though driving the vehicle took some 're-adjusting'
You had to complete learn to drive it all over again."
It all depends on how you try to optimise the active ride suspension. Most likely you could set it up to mimic the standard suspension but the gains were to be found in a more optimal aero platform and more optimal contact patch control. I worked on the development Honda active ride system at McLaren in 90, 91 and 92. I also worked on the McLaren ride height control system used in 93 until it was banned for 94.
"Never had telemetric data aquistion in those days. though they only let you use it practice now I think?"
Do you mean telemetry as in wireless transfer of data from the car to the garage? I ask because 99% of people seem to get this wrong! Although being in motor racing that should be a daft question!
We are able to use telemetry from the car to the garage all the time. But not from the garage to the car at any time.
Ian
