If we use your existing TX and assuming 10% regulation after rectification you will have approx 35-36v. With Ia peak at 5A your TX needs to be 350Va.
I would not use a resistor in the supply, as current demanded by the load IE during bass transients, will cause the voltage drop to increase/vary accross the R. I would regulate the supply.
