sq225917
Exposer of Foo
- Jan 11, 2007
1. Cambridge audio changed the design of the 840c when migrating most of it to the Dacmagic because the Toshiba optical receiver was no longer available. The part simply isn't made any more. The mods to my 840 are to the power supply to the DAC chips and the replacement of the XO with a tentlabs version and local reg.
Toslink input on the 840 first goes to the receiver and then onto the FPGA where it is resampled upto 384k, only after it has been upsampled is the signal then fed onto the parts that have been modded. Like I said if it handles 24/192 input on toslink from a myriad of other sources I can only assume that the AE is out of spec even at 16/44.1. Something which a quick search on Google supports.
2. You have shares in Apple, one has to question your bias, or certainly your disclosure.
3. Yes Apple replaced a poor design with another one.
One should not forget that the XO in the AE is within an inch of the Wifi chip, it couldn't be located in any worse a position for receiving Rf interference.
http://www.computeraudiophile.com/c...bearable-stuttering-will-macbook-be-different
So that's Cambridge Audio Who must be useless. EMM labs, who must be clueless fuckwits and know nothing about digital, and Musical fidelity ( who probably are clueless).
So, er, how's the water over there JC, any crocodiles?
