Lt Cdr Data said:
So in general....there are:
4 kinds of cartridge? moving magnet, coil, decca type and ...?
Yes, you have Moving magnet, Moving iron (Grado type, also called "variable reluctance" - describes my reaction to work), Moving Coil and Decca. On top you had cartridges using strain gauges (Win Labs) and optical pickups, plus now you have the ELP Laser Pickups, wjhich uses in effect laser interferometers to decode the groove.
Lt Cdr Data said:
3 kinds of stylus....spherical, elliptical, and hyper elliptical
Yes, boundaries are somewhat fluent, except for a spherical stylus. Hyperelliptical describes all sorts of "line contact" designs. Each of those will then of course have a radius in the actual active area...
Lt Cdr Data said:
...but the hyper is really not worth bothering with if you can't set it up accurately enough?
I have a tendency to say that hyper elliptical stylii really should only be used in linear tracking arms, with extreme care paid to alignment and with very easy and continous (ideally remote controlled) SRA/VTA adjustment, preferably with a memory system to easily call up the correct SRA for each record. There are one or two of those arms in existence, but they are hideously expensive.
BTW, the above does not stop me from using a hyperelliptical stylus cartridge in a normal tonearm, but it really only works well with special care to setyup and even then for only 10 - 20% of my LP's.
Lt Cdr Data said:
I am just wondering what happens when a record goes around...ie. it revolves say at 33rpm...does this mean 5cm/second,
No, the velocity of the groove varies from around 500mm/s (outer grooves) to 210mm/s (inner grooves).
the 5cm/s is actually the velocity of the signal cut at a nominal "0db". BTW, the maximum standardised cutting velocity is 25cm/s so you know there is 14db headroom build into the LP. Most cartridges track up to around 32cm/s at the max.
Lt Cdr Data said:
and the cartridge gives a proportional output?( usually taken at 1khz?)
Yes, proportional to the cutting velocity. Of course, there is also EQ applied....
Ciao T
