ATC's new
SIACD - Amplifier/CD/DAC
The new, compact, SIACD expands on, and is styled to match ATC's range of stand-alone electronic
products for home installation. The SIACD is built to the same design and manufacturing standards as
the company's internationally renowned professional audio products.
Overview
New class A/B "grounded source" 100W/Ch. power amp stages offering class leading performance
High performance DAC with USB, coaxial and optical digital inputs
On-board CD Player
Headphone amplifier with front panel mounted output
2 x stereo line level analogue inputs
1 x stereo line level output
Black or silver anodised finish options
6 year warranty*
Hand built in Stroud, UK
This new product is designed as a simple yet versatile onebox solution for D-A conversion, CD playback, pre and power amplification duties. The SIACD is housed in rugged yet elegant chassis, only 315mm/12.4" wide. Styling compliments the rest of ATC's range of outboard pre and power amplifiers and the product is available in both black and silver brushed and anodised finishes.
Whereas many other manufacturers' favour class-D power amp technology for compact devices, ATC have based the power amp design on the class A/B circuits employed in their highest performance professional, active loudspeakers, thus ensuring the highest possible performance of this vital element of an all-in-one player amplifier. In this revised design, ATC engineers have made further improvements to their discrete MOSFET output stage to give vanishingly low levels of distortion, very wide bandwidth and a reduced idle temperature. Maximum output power 100W per channel, continuous, into 8 ohms with both channels driven. The resolution offered by this approach is simply above and beyond what is available from most 'high-end' stand-alone power amplifiers, let alone 'all-in-one' player/amplifiers.
The preamp/DAC stage features two, line level, stereo, analogue inputs and three digital inputs. Both analogue inputs are equipped with rear panel mounted, RCA/phono connections. One of the two inputs also features a front panel mounted 3.5mm jack input for simple connection to portable music players. The USB, SPDIF and optical inputs are mounted on the rear panel.
The DAC utilises Wolfson's WM8740 chipset and is compatible with 16 to 24 bit word lengths and sample rates up to 192kHz (coaxial and optical digital inputs only). Excellent digital clock recovery ensures signal integrity is maintained even with poorer quality digital sources and the SIACD. The USB input is compatible with word lengths up to 16 bits and sample frequencies up to 48kHz and is galvanically isolated from the digital source via a high performance transformer.
The SIACD headphone amplifier is specified to drive a very wide range of headphone sensitivities and impedances. It features very low distortion and noise and an extremely wide and flat frequency response for best possible performance. The headphone output is front panel mounted.
The chassis is constructed from a combination of steel and aluminium and uses constrained layer damping to control panel resonances. The front panel is machined from an extruded section of 13mm/0.5" aluminium alloy with a brushed and anodised silver or black finish. All the user controls are machined from solid aluminium.
Specifications
Integrated Amplifier
Max. Power Output (Continuous Av. 8 ohms, 1kHz, both Channels driven) 100W
Line Inputs: Two, stereo (one with additional front mounted 3.5mm jack).
Line Input Sensitivity: 640mV
Input Impedance: 13k8 Ohms
Line Outputs: One, stereo
Line Output Impedance 10 Ohms
Frequency Response (-3dB): < 2 Hz - > 250 kHz
Total Harmonic Distortion (8 Ohms, -1dB below full Power): 1 kHz <0.0015% (-96dB)
10 kHz <0.002% (-90 dB),
Crosstalk (10Hz – 20kHz): >80dB
S+N/N Ratio: > 100 dB (Wide band)
> 110 dB (DIN)
> 115dB (IEC "A")
Absolute Phase: Phono Zero Degrees
CD Player
Distortion: 1 kHz <0.002% (-94dB)
10 kHz <0.003% (-90dB)
Frequency Response (+/- 0.1dB): 20 Hz – 20 kHz
S+N/N Ratio: >100dB (IEC "A")
Digital Inputs – Coaxial & Optical
Distortion: 1 kHz <0.0025% (-92dB)
10 kHz <0.004% (-88dB)
S+N/N Ratio: >96dB (IEC "A")
Supported Word Lengths: 16 to 24 Bit
Supported Sample Rates: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz
Digital Inputs – USB
Distortion: <0.005%
S+N/N Ratio: >96dB
Sampling rate: 32kHz, 44.1Khz, 48kHz
Mains Power
Voltage: 115/230V AC 50/60Hz (internally selectable). 100V AC via dedicated transformer
Maximum Power Consumption: 300VA
Physical
Dimensions (HxWxD) 112 x 315 x 425mm / 4.41 x 12.40 x 16.73"
Weight 9.6kg/21.1lbs
The unit is supplied with an IR remote control. The SIACD is covered by a six year warranty (*1 year CD mechanism).
***** Musicraft - Clearance + Special Offers list
https://www.audio-forums.com/as-rediect/showthread.php?t=28303 *****
Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
