ATC + Reviews - At Musicraft (Derby)
Stereomojo review ATC's curved SCM11 passive monitors
http://www.stereomojo.com/ATC SCM11 Version2 Speaker review/ATCSCM11Version2review.htm
Second Generation SCM11
The new SCM11 features ATC's SH25-76 with an ATC CLD 150mm mid-bass driver incorporating a 45mm soft dome. Constrained Layer Damping is a driver cone technology exclusive to ATC and represents a step-change in driver-to-system performance. Advantages include reduced harmonic distortion between 300Hz and 3 kHz, an extended frequency response that eases constraints on the crossover filter slope, and improved off-axis response.
***** Musicraft - Clearance + Special Offers list https://www.audio-forums.com/as-rediect/showthread.php?t=28303 *****
***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Btw, Yamaha Aventage RX-A1020 AV receiver (DISPLAY UNIT - NOT USED) in Black finish RRP £1000_____Was £700_____Now £600
***** Please call before travelling *****
Thanks
Rick @ Musicraft
ATC SCM110ASL Professional installation at Steffen Muller Mastering
The ATCs are in! What a relief, and what a big improvement over the B&Ws. The Nautilus N802 are absolutely great speakers but for working the ATCs are just another level. We already did a few records on the new system, plus extensive listening/testing and the results are pretty stunning . Still a few cosmetics to do....
Btw, Monitor Audio Radius R250HD (demo/display) - speaker only - in Piano Black finish RRP £275_____Now £110
Thanks
Rick @ Musicraft
ATC's new Special Edition S50 monitors featuring their new Super SH26-76 HF unit
To celebrate ATC turning 40 years old, ATC have manufactured a limited run of 10 pairs of Special Edition S50 Loudspeakers. The S50 was the first ever ATC HiFi Loudspeaker. The 2014 edition uses a 9″ SL Bass driver, a Super Midrange Dome and the new ATC S Tweeter. It comes in either active (P6 powered) or passive form. All metalwork is finished in dull nickel and the baffle is covered in real leather.
Thanks
Rick @ Musicraft
Stereophile review ATC's curved SCM19 passive monitors
http://www.stereophile.com/content/fifth-element-85
Featuring the new ATC designed and built 25mm soft dome tweeter, updated bass/mid drivers and crossovers housed in a curved, laminated cabinet, the first of a new range of ATC closed-box passive loudspeakers has arrived. The second generation SCM19 employs ATC's landmark SH25-76 tweeter, developed to satisfy the company's long-established rigour in drive unit engineering.
SH25-76 Tweeter
Sharing technology with the renowned ATC soft domed mid-range drive unit, the new tweeter employs a unique dual suspension system suppressing rocking modes even at high power output levels. The ATC configuration of a short edge-wound voice coil in a long, narrow magnetic gap ensures exceptionally low distortion throughout its operating band and removes the need for ferrofluids, which can dry out over time, compromising performance.
A complex, shaped, soft-domed diaphragm extends high frequency range and offers a smooth off-axis response. The tweeter's 15,000 gauss (1.5 tesla) neodymium magnet has a black heat-treated top plate, which dissipates heat away from the voice coil to maintain high power handling and low power compression. A precision-machined 5.5mm rigid alloy waveguide provides optimum dispersion, a flat on-axis frequency response and resonance-free operation.
ATC SH25-76 tweeter
New Cabinets and Systems
Establishing what is to be a new style for ATC's most competitively priced range of loudspeakers, the new SCM19's benefit acoustically and aesthetically from a curved cabinet construction. Braced and laminated for high rigidity and damping, the curved enclosures in real cherry or black ash veneer also impart a strong impression of design quality. Improved crossovers featuring metallised polypropylene capacitors, large air cored inductors and ceramic wire-round resistors offer superior power handling and clarity. The SCM19 exhibit an impedance curve free from low values, presenting an easy load for amplifiers of 75 to 300 watts. The SCM19 is designed for optimum performance with the grill in place – although the difference in performance without the grill is minimal. The metal grille, finished in anthracite grey, fixes to the cabinet via hidden magnets. According to tradition, each model number represents internal cabinet volume in litres.
Second Generation SCM19
ATC's SH25-76 soft dome tweeter is joined by the company's highly linear 150mm mid/bass driver. It features an integrated 75mm soft dome – exceptional for its horizontal dispersion of mid-band frequencies – and a huge 9kg high-energy, 'Super Linear' magnet system, which includes a 75mm diameter flat wire, underhung voice coil, meticulously milled and formed by ATC. The magnet system and a carefully weighted doped fabric cone assembly contribute to the SCM19's wide bandwidth, impressive dynamic range and convincing bass output coupled with very low distortion as a result of the unique 'Super Linear' motor system.
ATC curved SCM19 monitors
Thanks
Rick @ Musicraft
ATC SIACD and curved SCM7/curved SCM11 Special Package Offer
SIACD + SCM7 (pair) - £3325 (£3902)
SIACD + SCM11 (pair) - £3625 (£4292)
SIACD + PR SCM7 AND PR SCM11 - £4300 (£5102)
INDIVIDUAL PRICE FOR COMPARISON (RRP)
SIACD BLACK/SILVER - £3092
SCM7 (pair) CHERRY/BLACKASH - £810
SCM11 (pair) CHERRY/BLACKASH - £1200
SIACD
curved SCM7
curved SCM11
Thanks
Rick @ Musicraft
Technical data for ATC's new Super SH25-76S Soft Dome Tweeter
The SH25-76S is ATC's premium 25mm soft dome tweeter, designed and built with the same no compromise philosophy as all other ATC drive units and to perfectly compliment the renowned SM-75-150S Super Dome mid-range driver.
Unlike almost any other 25mm tweeter on the market the SH-25-76S is a dual suspension design which ensures pistonic motion, suppressing anhramonic rocking mode, even at high drive level, and enables the use of narrower magnetic gaps, this, along with a short coil, long gap configuration ensures unparalled lineraity and incredibly low distortion throughout its intended operating band. The soft dome diaphragm is based on a complex geometry which maximises power transfer from the former, extending the high frequency response and giving a smooth off-axis response.
The massive neodymium motor with heat treated top plate is optimised to give a 20,000 gauss (2.0 Tesla) in the magnetic gap, extending the frequency response well beyond 20kHz and resulting in moderately high sensitivity, even with the very strong, well-damped structures employed. The huge motor assembly also performs the secondary function of dissipating heat away from the coil and ensuring high power handling and low power compression. The motor topology and moving assembly design negate the requirement for ferro fluid. The SH25-76S is therefore, free from the detrimental effects of this drying out over time.
The geometery of the waveguide is designed for optimum dispersion and an extended on-axis frequency response. It is made from a precision machined alloy so that the entire structure is extremely rigid and free from resonances.
Specification-
Sensitivity: 91.5 +/- 0.5dB/W @ 1m
Nominal Impedance: 6 ohms
Frequency Lineraity (+/- 2dB): 1.5kHz to 22kHz
Cut-Off Frequency (-6dB): 26kHz
Dispersion: +/-80 degrees Coherent
Magnetic Gap Height: 3.0mm
Coil Length: 2.0mm
Magnetic Gap Flux Density: 2.0 Tesla/20,000 Gauss
Weight: 0.34 kg
Thanks
Rick @ Musicraft
Hi-Fi Choice review ATC curved SCM40 passive monitors
http://www.atcloudspeakers.co.uk/wp-content/uploads/2014/09/HiFi-Choice-Oct-2014-ATC-SCM40.pdf
Second Generation SCM40
The new SCM40 features ATC's new SH25-76 tweeter with a ATC's renowned 75mm/3" Soft Dome mid-range and a 164mm, short coil – long gap (underhung) bass driver. The three-way design and inclusion of the Soft Dome mid results in excellent clarity, even at high drive levels with bass heavy souce material. It also gives wide, even dispersion resulting in excellent stereo imaging and un-fussy positioning in the home. The new model also benefits from crossover revisions that have improved the loudspeakers overall balance and the integration between mid and high frequency elements.
ATC curved SCM40 monitors
Featuring the new ATC designed and built 25mm soft dome tweeter, updated bass/mid drivers and crossovers housed in a curved, laminated cabinet, the first of a new range of ATC closed-box passive loudspeakers has arrived. The second generation SCM40 employs ATC's landmark SH25-76 tweeter, developed to satisfy the company's long-established rigour in drive unit engineering.
SH25-76 Tweeter
ATC SH25-76 tweeter
Thanks
Rick @ Musicraft
ATC's curved SCM11 passive monitors - What Hi-Fi Awards 2014 winner for best standmount speakers up to £1200
http://www.whathifi.com/atc/scm-11-2013/review
SH25-76 Tweeter
Thanks
Rick @ Musicraft
ATC's new curved SCM40A (active) monitors
SCM40A Active monitors to launch in January 2015
January 2015 will see the introduction of ATC's new curved SCM40A floor standing monitors. As the name suggests, the curved SCM40A is an active version of ATC's highly successful curved SCM40 passive monitors. The 3-way design, employing all hand built ATC drive units is complimented with a built-in 235Watt class AB tri-amplifier. The MOSFET based amplifier is a modified version of that found in ATC's larger active monitors, the SCM50ASL, SCM100ASL and SCM150ASL.
Thanks
Rick @ Musicraft
ATC's curved SCM19 passive monitors - Stereophile's Products of 2014 Editor's Choices of 2014
http://www.stereophile.com/content/s...s-choices-2014
SH25-76 Tweeter
ATC SH25-76 tweeter
ATC SB75-150 SL mid/bass drive unit used in curved SCM19 monitors
Thanks
Rick @ Musicraft
ATC will be exhibitibing at CES Show 2015 (Las Vegas 6th - 9th January) - The Venetian Hotel Floor 29, Suite 325. CES 2015 will see ATC launch their new curved SCM40A (active) monitors
The curved SCM40A is an active version of ATC's highly successful curved SCM40 passive monitors. The 3-way design, employing all hand built ATC drive units is complimented with a built-in 235Watt class AB tri-amplifier. The MOSFET based amplifier is a modified version of that found in ATC's larger active monitors, the SCM50ASL, SCM100ASL and SCM150ASL.
SH25-76 HF drive unit used in curved SCM40A active monitors
ATC SM75-150 soft dome mid range drive unit used in SCM40A active monitors
ATC SB50-164(SC) bass driver used in SCM40A active monitors
Thanks
Rick @ Musicraft
ATC will today launch their eagerly awaited curved SCM40A (active) monitors at CES 2015 (Las Vegas)
Thanks
Rick @ Musicraft
ATC at CES 2015 update -
We are all set up and ready to play our New Active ATC curved Active SCM40s! You can also hear all of the passive series in our CES suite at the Venetian! (Lone Mountain Audio)
Thanks
Rick @ Musicraft
ATC's new curved active SCM40A monitors have received a What Hi-Fi Stars of CES 2015 Award
http://atcforums.co.uk/pdf/ATC CORP BROCHURE.pdf (ATC Corporate brochure)
Thanks
Rick @ Musicraft
ATC will be exhibiting at the 2015 NAMM Show (January 22-25), held at the Anaheim Convention Centre, CA, USA. ATC will be launching a new product at NAMM this year! You will be able to find ATC on the Transaudio booth, #6945
https://www.namm.org/thenammshow/2015
Thanks
Rick @ Musicraft
ATC's new curved active SCM40A monitors - IN PRODUCTION
Thanks
Rick @ Musicraft
