Cables??????
I have not tried a different lead to the PSU as it has a big thick jobbie already. I did think that the speaker cable could make a difference as the importer recommends some very very expensive stuff called Audience.. But on the basis of what I have heard I can't see the point...
I would welcome your suggestions WM as although I am happy, I also like to play around and improve what I have too...
the one caveat is I always test these things blind and that seems to make a difference...
Go with your ears. If you can't hear the difference, there is no difference. Sometimes the envelope just refuses to be pushed.
As for Paul's avatar, I keep waiting for one or both of 'em to pop out.
Jools, tis cool, you could ask Henry about the Au24, he's been trying some out over the last 2 or weeks
Well, blind is fine, I would like to come down and have a play, if you so wish, The Lavvy is a good amp, and responds to various stimulii :rolleyes: :confused: :D
If we make no difference, then cool, least you've had a bit fun trying :)
The size of the cables doesn't neccessarly matter, the AU 24 is amere 4mm thick, (example).
How far apart are you Speakers?, are they on concrete/granite plinths? how many I/c's do you use? p/leads etc? Wm
0 Words
