the key phrase is 'reducing jitter', the dac cannot eliminate jitter.
Without professing any technical expertise here, the combination of transport performance, especially 'clocking', and proprietal encoding of signal from transport to dac makes a great difference. Like a number of dacs, the Dax Decade does some re-clocking once it gets the signal but its output is surely still dependent to some large extent upon the input it gets, as time-based media.
My transport has a little switch at the back that allows me to toggle between S/PDIF, C-code (which is S/PDIF with the package headers removed, I think) and N-code (which is an encoding by AudioSynthesis). The results are dramatic improvement, as Nic has told me, and Dunkyboy, Alanbeeb and Shrink have had demonstrated to them.
Now it's only fair that I should tell you that I picked up my transport s/h for £200 and then had this pre-modded machine further enhanced for £40 when I upgraded to BG on the Dax Decade. By far the best value upgrade ever.
edit: corrected 'spelling' of S/PDIF, http://whatis.techtarget.com/definition/0,,sid9_gci213474,00.html
