wadia-miester said:...snip
Something else for Andrew
"In the test results displayed on the Benchmark website, the Jitter amount used as a test signal is varied. However, the Jitter amount which comes from a slaved CD player is constant. What's not mentioned about the "UltraLock" asynchronous resampling is: the compromise of running two clocks in tandem is that there are unpleasant audible artifacts due to inevitable frequency discrepancies between the two clocks involved."
Your unattributed quote is incorrect. The three jitter graphs do not all use a slaved CD player, nor do they use jitter of constant amplitude and frequency, as you will see if you download the full manual from the website. You will however notice that the engineers at Benchmark are quite poor at spelling, for which I am inclined to forgive them since they are very good at building DACs.
Also there are no "unpleasant audible artifacts" in my ears. There may be inaudible and unmeasurably small artifacts though...
Andrew
