So after far to much soul searching , navel gazing, and hair pulling .. I have just put in an order. To the values found on the board, and not the schematics posted here ... For. Solen MKP 400v ... With the exception of a 600v 1uF to run in parallel with the 400v 2.2uF .. to get the 3.7 uF
Falon acustics in there blurb seem to be recomending the Alcap .. but charging more for MKP ... !!! ???
So now I have my usual buyers regret ... But that was always gonna happen![]()
There's a good reason for Falcon, who DO know their stuff, to recommend the Alcap over Solens or whatever.
That's because when the crossover was designed, they took into account the electrical characteristics of bipolar electrolytics, which are different to plastic-film capacitors. Using plastic film capacitors will mean that the crossover will be different. You might prefer it, especially if buying something more expensive, but it will be different.
Furthermore, Elcaps are physically much smaller than plastic film capacitors so will fit the space on the crossover better, especially as today's elcaps are considerably smaller than the elcaps originally used even if the characteristics are the same.
If the original design used elcaps, that's what I would stick with. Just get them voltage rated at least what the originals, going up in voltage rating will do no harm, and will be beneficial as today's amplifiers tend to be more powerful.
S.
