D.a.b. Or Analogue Tuners?
Thanks Tony, that certainly made a lot of sense and is very helpful. I'll take it on board and quietly look out for a Sony to try unless I spot something else along the way. Paul's right aobut the music mattering most of course, nice to hear it as enjoyably as possible if one can.
The best site is www.fmtunerinfo.com
It's a goldmine of info about tuners. You want the most gangs and filters you can afford. That way you'll have the best sound.
I think 70's supertuners are the most affordable means into the high end you'll find. A good one is absolutely stunning.
nando said:
i have, got a LUXMAN T80V, M.F.X-PLORA, BUT I AM TRIYING TO PERSUADE MY FRIENDS THAT ANALOGUE TUNERS ARE BETTER BUT TO NO AVAIL, P.S. IF YOU ARE INTERESTED:my kit: T.T.-AVID ACUTUS, SME309, AT OC10 CART. NU-VISTA 3D CD, PLUS KW25 TRANSPORT AND DAC, TUNERS AS MENTIONED, NU-VITA M3 INTEGRATED FOR THE TREBLE, NU-VISTA 300'S PWR FOR THE BASS, PROJECT SE PHONO STAGE, CASTLE WINCHESTERS, "SPECIAL EDITION" AND LOADS OF VINYL, OLE...
Have you got any pictures?
why have you got such a relatively poor phono stage for your great TT? (although the cart is letting it down slightly) and why two CD players?
used to have a troughline 2, bought it with a built in decoder (philips) which was done in 1967 by pax, at least it said so.
I had the troughline serviced and changed the decoder to a onething, sounded a lot better. total cost was 110 euro for service which also had caps change.
Some ime later I change to a scott 335 mxp decoder, ehich is american sixties tube. A lot more expensive but sounding better. If I had a troughline I would go for a scott 335 or fisher mpx-100.
The only two issues are 110v and the decoder needs a change from 75 to 50 ums I believe, otherwise it sounds too dark. So you will need a very good technician and a manual.
Now I could buy a fisher fmr-1 (like a fm-1000 but with rack handles). This is a better tuner but a lot more expensive.
Troughline is now at my parents and never had any problem. The onoly thing is it received only 9 channels very clear with magnum dynalab 2t-2 on the roof but surrounded by too many high buildings.
________
tempo
