DIY Mains cable bits
I received mine yesterday and tried them last night.
I have both pre and power hooked up to 1.5m of 2.5 cable.
They look superb and sound just as good.
Big Big improvement over standard leads. Without any burn in, the difference is night and day. More weight, more clarity, scary realistic bass.
Well done Andy. Highly recommended.
Another power cable convert ........
There'll be someone along soon saying it can't possibly make a difference !!
Cheers mate, much appreciated!
Apologies but theres no 2.5mm cable left for the moment. Should have it again in 8 or 9 days time. Will post when I have it again.
No more 1.5mm cable left. I won't be stocking any more of this as most people seem to prefer the 2.5mm anyway.
Sorry, no more cable for the moment, last lot has lasted only three days when I expected it to last until Xmas. More on order but will be a week or so before I get it. Sorry!
just wondering what really makes a good power plug?
can't bother (or couldn't go mad enough) to try and listen different power plugs, i bought the following - rather cheap, rubber-covered 10A plug (i'm based in europe):
it feels pretty solid in hand and it costs nothing (3E with german big supplier conrad).anything seriously against this kind of things? it should work with a usual 3x2.5mm lapp cable and it can nicely fit through an elastic hole on the back.
lapp cable is so hard to manipulate with (cut, bend, etc) that once the connectors are fitted, i don't think i will bother next 10 years with the power cords in my house so it's good to know if i should go for anything better before the job is done.
anubisgrau said:
and that's all? no gold, no rhodium, no platinum?
Well there are a few other things, like can the plug accommodate large cable diameters and does it have a decent cable retention mechanism, the maximum size of conductor the pins can accommodate, ideally they should be able to hold 2.5mm conductors or greater.
Unfortunately my holidays is now over and I am back in the UK. Everything for sale again as per 1st post.
