Originally posted by lowrider
Thats what I have and recommend, but one somewhere between the speakers wont make itself too obvious, if it is properly setup, and xover up to 60hz... :MILD:
Also, I hear that deep bass is usually mono, same from both stereo speakers, I wonder if that is true...
There are two issues to the 'deep bass is usually mono' question and they should be considered separately.
Firstly there's the recording. Generally, on LPs deep bass is in mono whereas on cds it can be recorded in stereo.
Secondly there's the question of at what frequency we can detect the location of the bass. This depends on room size (I believe) and in practice also depends on the steepness of the crossover slope, speaker and amplifier distortion and speaker cabinet. In other words, when we play a frequency of, say, 60Hz, we may be hearing harmonics at 120 and/or 180Hz and it may also excite cabinet vibrations (and standing waves). This will give us location information that we wouldn't get with a pure tone.
If the subwoofer content is really below 60Hz (with a reasonably steep crossover slope and low distortions, resonances and vibrations), you could place the subwoofer in a room corner and not detect its location. Corner positioning will excite the room modes and give a louder output. This may be a good thing, particularly if you're using equalization, as it's easier to remove the peaks than to fill in the troughs and the extra efficiency is useful.
If I've said it once I've said it a thousand times, there's no such thing in hi-fi as .... wait a minute, you're just winding me up lowrider, aren't you?
Ok, cancel all of the above.
