Markus S
Trade
BerylliumDust said:The link you gave me doesn't work
Strange, it works for me. Others?
Markus Sauer said:BD, the link doesn't make the physical layout of the test set-up at all clear to me. There are conncetions labeled A, B, C and D, but what those connections are is not specified.
wadia-miester said:You forgot to add Imho
Tube_Dude said:But why , do you must do the test only with 2 volts...you can use a signal with the voltage you want ( driving the the amp under test by another amp for ex. ) and of course , in this case ,the test become even more stringent ...![]()
QUOTE]
That's it! So simple... how dumb I am...
We are all lost Markus... and we are too proud and dumb to admit it!
You can do it yourself at home if you have an old or spare amplifier. Just connect the CD player output (one channel) to the input of the amplifier being eveluated. Simultaneously connect the + signal of the same CD player output to the + input of the other (spare) amplifier. Take the + speaker output of the first amplifier (under test) and connect it to the ground (normally its chassis) of the spare amplifier. Connect the spare amplifier output channel (the same as the input) to a speaker.
wadia-miester said:I wonder if you know what Markus actually does for a Living BM?
