Originally posted by Matt F
This is absolutely spot on ââ'¬â€œ low distortion is the key and when you first hear low bass with little/no distortion it can be a bit weird ââ'¬â€œ it sounds like there is less bass until you get used to how clean it is.
It's not difficult to play cleanly at low volumes or at high frequencies but to play cleanly at decent volumes down at the lower frequencies (>25Hz) is where it becomes tricky and that's why subs with minimal distortion are thin on the ground ââ'¬â€œ a few DIY designs (Merlin, take a bow), some expensive servo controlled-units and a few cheaper gems such as SVS and Paradigm's Servo 15. As Merlin says, you are almost always talking about big enclosures, big drivers and plenty of power.
Unfortunately, distortion figures are hardly ever quoted ââ'¬â€œ you can hazard a guess at why ââ'¬â€œ let's just say that it would not make pleasant reading. I know that Nic Rhodes (no not that one - a member over at avforums and a respected engineer) has measured distortion figures for loads of popular subs ââ'¬â€œ according to him it was not uncommon to see distortion figures of 30-40% from some of the little ââ'¬Å"5 starââ'¬Â boxes!
I also agree about the nonsensical specmanship regarding how low subs will go. The fact that these specs are incomparable due to various reasons (different ââ'¬â€œdB readings, "in room" vs anechoic) makes the whole thing laughable ââ'¬â€œ according to specs an REL Q200 (small box, 10ââ'¬Â cone, 200 watts) drops to 17Hz but a Velo HGS15 (big box, 15ââ'¬Â cone, 1250 watts) only manages 18Hz but the former is ââ'¬â€œ6dB "in room" and the latter is ââ'¬â€œ3dB anechoic. The Q200 at ââ'¬â€œ3dB gives 25Hz ââ'¬â€œ remove room loading and we'd be talking more like 30Hz.. Yamaha take the biscuit ââ'¬â€œ they use ââ'¬â€œ10dB figures!
What would be good would be for a standard to be applied ââ'¬â€œ say ââ'¬â€œ3dB anechoic. It would be really interesting though if a maximum distortion limit was used too (say 10%). Tom V of SVS published a list a while back showing the maximum depth and output of a whole host of subs using a 10% distortion limit ââ'¬â€œ it made interesting reading ââ'¬â€œ a lot of them looked much less impressive when limited in this way.
L Hatkins ââ'¬â€œ yes I am the same Matt F and I can vaguely remember the debate. I think I was arguing that bass below a certain frequency (i.e. where it become non-directional) doesn't need to be in stereo because the positioning cues out brains use is taken from the harmonics and that this is why home cinema only needs to use one channel for LFE (which is generally below 80Hz but can theoretically be up to 120 Hz, I think),
Enough from me.
Matt.
