On the subject of passives with transformers, i had a listen to a Music First Passive Pre. Very nice, utterly trounced my PV-10. Not cheap at around £1500 though but sorely tempting nevertheless
What did you learn?Originally posted by timpy
Cracking post Dean, thanks, interesting reading, not least beacause I've just learnt something that until now I had misunderstood!!
Yep, the remote Passion Ultimate from AS, that was the one and only pre (so far) I have on my mental shortlist should I ever decide to go back to the pre/power route again. What do you think of it Dean in comparison to other pre's you've experienced or have in your collection? Also, do you have any experiences with the phono (Passion Phono) version of that pre?Originally posted by SCIDB
The pre I use is here.
Not come across that one before. Looks very interesting/tempting to me too, even has balanced connections too. :MILD:Originally posted by badchamp
On the subject of passives with transformers, i had a listen to a Music First Passive Pre. Very nice, utterly trounced my PV-10. Not cheap at around £1500 though but sorely tempting nevertheless![]()
Thorsten Loesch? Can't quite pin him down but I hear his name all over the place. Does reviews at enjoythemusic.com and makes a DIY preamp kit I think.Originally posted by LiloLee
the Stevens & Billington are considered to be better and as used by Thorsten (if that means anything to anyone here)
At a group gathering we compared my 3 passives. My DACT/WAD (holco rebuild)/Sowter TVC. The WAD was considered best, marginally edging out my DACT. The Sowter was wierd. Technically it was the best for hifi, it was just that it sounded slow and lost out on the timing of music.
It must be said that they were prototype Sowters and the Stevens & Billington are considered to be better and as used by Thorsten (if that means anything to anyone here)
Let us know what you think of the AS Passion Phono then when you get a chance to have a play with one. I'd be interested to know if I'd be a worthwhile box swap / box reduction exercise in the event that I end up with a power amp set-up and only effectively need a volume control for my t/t (as the CDP might have it's own built-in volume control facilities going straight into the power amp which has two switchable inputs).Originally posted by SCIDB
I have not heard the Phono stage. But it is rated to be very good. I hope to get a play with this item at some stage.
