That is what I tried to suggest to Mosfet even before the test. However, he think it would be too difficult to explain to listeners how to do this but I never understand why that is should be the case.
Thank you for your smugness. [edited by Dev]Amusing.
No. The testers were not required to pass golden ears tests parts one thru seven nor record their responses to the tritone paradox. It was assumed they were of normal and representative hearing ability.First, may I ask if any controls where done to validate the test-setup and participating listeners agains "known audible" stimuli?
Please read the method at least. Efforts were made within the limitations of what could be achieved.as no effort was made to illustrate what could be actually identified relaiably under the test conditions.
And the ââ'¬Å"reasonable certaintyââ'¬Â of sticking felt dots around the room to influence the room acoustic is again?Past that, once we have evened out the chances of type a and type b statistical errors we find that we have insufficient data to draw any conclusion with any reasonable certainty.
I can supply this information to you if you wish ditton. It would be necessary to maintain anonymity of who thought what specifically (this is possible) because this was an assurance given.'I deliberately did not record who made which observations because I was anxious that this should be a test of cables, not of people'. Shame, as this reduces the power of the test, and so the number of judges (n) would likely have to be larger than 3.
There isn't. Statistical analysis, whichever methodology you choose, is all about showing that the results obtained were very unlikely (usually less then 5% chance is the chosen breakpoint) to have occured by pure chance alone.zanash said:but I still think there is in suficient data in the test.
If you had shown that the listeners were able to distinguish a "known audible" difference without fail you would not only have validated the listeners hearing ability but also the ability of the system (inc. room etc) to be able to resolve such small (but audible) differences. Since you think it's OK to assume that was the case it's quite reasonable for anyone to assume it wasn't. The more assumptions you can eliminate in any experiment the more indisuptable the results.mosfet said:it was assumed they were of normal and representative hearing ability.
Surely the results show that the listeners 'conscious choice' was the same as tossing a coin, and therefore the cables didn't make the system sound different. Which seems a meaningful (and expected...) result.If instead of making a conscious choice in each test the listeners had just tossed a coin to decide their answer it's quite likely that similar results would have been obtained. On that basis the results are meaningless.
So 13 out of 15 times an audible difference was noted. But of course you can just wave that away I guess.
The testers were deliberately predisposed to hear differences. The failure to spot the control by two out of three is telling. It would have been interesting to see more runs of the control test.So 13 out of 15 times an audible difference was noted. But of course you can just wave that away I guess.
Paul Ranson said:The testers were deliberately predisposed to hear differences. The failure to spot the control by two out of three is telling. It would have been interesting to see more runs of the control test.
And cables are notoriously system dependent
As I said, the test results are sadly of no use at all
