3DSonics
away working hard on "it"
Actually, note, I personally use the same mains cables described extensively in my own system, so I do not find the personally unacceptable (I also have some other commercial mains cables around), I merely recommend to the normal HiFi Enthusiast not to use specialist mains cables that they cannot verify are fully safety approved.
I have seen some seriously funky stuff as mains cable which made me doubt the sanity of the designers.
Note, the SPECIFIC cable described in TNT Audio, WHEN CONSTRUCTED COMPETENTLY AS DETAILED are electrically safe insofar that they have sufficient insulation for the voltages involved, the PEN (Protected Earth Neutralised IIRC) conductor is of more than sufficient crossection to pass the standard "PAT" testing (all my own cables are PAT tested) and the conductors for the life & neutral are of sufficient crossection for the mains cable to be fused with 13A according to UK mains code even if CT/FT-100 is used and the insulating materials are self extiguishing.
I suspect that if someone would want to produce this design commercially they would be able to gain the neccesary certifications for electrical and fire safety without problems, merely at a quite significant expense for the testing labs.
I would not have written about the subject without making sure that safety is well accounted for (I am after all formally qualified as Electrician and Electronic Engineer, including having held the ability to self-certify my own installations back in Germany). So, to describe this as irresponsible is more than strong toback, hence I am taking exception here.
That too. Not just factually wrong and with questionable intentions, but off topic as well....
L8er T
mosfet said:To me it is hypocritical to suggest an endeavor that involves risk while similarly stating the level of risk is personally unacceptable because of a lack of appropriate safety approvals.
mosfet said:You should recognise Thorsten that people will read your articles and because of your extensive technical knowledge, that I acknowledge, will tend to believe all is well despite the safety warnings. Irresponsible in my opinion.
mosfet said:Albeit a side issue to this thread.
L8er T
