wadia-miester
Mighty Rearranger
Right, just for you lot I thought I 'Show you' what a digital out put signal looks from a Transport
It should be a Square wave form.
Sorry the Photos are big, but I aint got time for cutting em down at the moment.
Ok, the first photo shows an output signal from a Stock Rotel RCD965BX (16 bit 44.1), using a Quality cable and straight to a 75 ohm dummy load, the second is the same player going through a recloacking latch and src (Pet Tec P1-A as a 24 bit/44.1 signal)
Notice the digital 'reflections on the first piccky' and how after going through the P1-a they are all but gone, it's not the best photo, but you can get the jist. Wm
Stock Rotel into Dummy Load
Now using the P1-a
Now using the P1-a
