Tact question
ShinOBIWAN said:
Neither the DEQX nor Tact are particular good at DRC. People will tell you they are but don't believe it, they're not. The DEQX is good for speaker correction and crossover duties though. The Tact doesn't offer the flexibility of the DEQX even with the add ons, so overall I'd say its expensive product with little appeal.
You can buy the DEQX from either the manufacturer in Australia, Overkill Audio(expensive modded version) or Tekcare here in the UK:
http://www.tekcare.co.uk/Scripts/prodList.asp?idCategory=1235
My first DEQX I bought from Tekcare and I can highly recommend them. Very helpful and speedy delivery
What I think I am after ? is something to mainly clean up the lower registers, but also replace/replicate the options the K-UBE gives me with extension, Q factor and contour , but without losing any transparency or quality. To be honest I am not sure what the best option is here ?
The system , Kef Reference 107 (single wire) with Krell KRC 3 pre and Krell 250 power, the room L shaped with plasterboard. There is some bass lift noticable on the left side of the room, particulary I think in the rear left corner. (I would like something completely transparent which be put in between the pre and power with XLR connections)
The problem with the K-UBE is it masks some treble detail and quality, and is not balanced (which I prefer), and although the 107 sounds not too bad without the K-UBE the frequency responce is not quite as even, with slightly lifted treble and bass rolling off earlier , I find the K-UBE controls quite useful , and without it dynamics and even frequency down to the lower registers is affected. (I dont know if I could have the K-UBE rebuilt to offer XLR options and more transparency ?)
The Tact sounded interesting, as it is a pre, DAC and has room correction and may completely remove the need for the K-UBE, but I never did find out if it was a better quality option than the KRC 3 pre and Theta Pro Basic IIIa dac ( Or a KRC HR with Theta Pro Gen Va) with external room EQ ?
Of course changing the speakers may help, but the 107 is quite child proof, and the coupled cavity gives I find more options with room placement, with the K-UBE (or even an old Meridian 602) I can place these 1m into the room or against the wall, I am sure a speaker which goes down to 20hz with a large bass driver facing into the room would create more problems than the 107 coupled cavity ? (in fact the only problems I have with the 107 apart from a couple of the usual room related problems, is the use of the K-UBE and the T33 tweeter, It would be nice to fit something better in there)
Maybe I am just too atached to the damn things, after all I have been using them for years.
It depends what dsp you are doing. Nonlinear signal processing takes a lot of horsepower.
Agreed about what is currently available though - but then thats true of almost everything in audio. In the main its a conservative and undistinguished field in terms of technology. The chips in the behringer kit are pretty cheap.
